wheel spacer have you tried 5mm, 10mm, 20mm?
Discussion in 'Exterior' started by Mrcorolladeaf, May 10, 2013.
    Mrcorolladeaf DEAFNESSCREW
    Turlock, CA
    98 corolla 1.8L VE
    If anyone had done before which is the best MM on corolla? or do I have to buy long bolt for enough room rim nut?
    It all depends on the rims you have, what kind of look and fitment you are going for, if you have rolled your fenders, the easiest way is to measure it yourself.
    Mrcorolla79 likes this.
    I've got the 5mm spacer, you can use them on most wheels with stock studs.
    If you're going to run spacers wider than 5mm you need longer studs or hub adapters.
    The rule of thumb is the lug nut must cover as many threads as the thickness of the stud. In our case the stud is 12mm, so your lug nut needs to be tightened at least 12mm down, or since it's 1.5mm/thread, 12mm/(1.5mm/thread) = 8 lug nut turns.
    In summary, if you can do 8 turns with your lug nut, you are good with whatever spacer.
    Spacer
    Hub Adapter
    Turlock, CA
    98 corolla 1.8L VE
    I haven't rolling fender yet but soon, I ll gonna play with measure see how it goes, thanks
    Also hubcentric spacers are a great idea.
    Turlock, CA
    98 corolla 1.8L VE
    thanks james I get it clear.
    I rolled to LA and back with no hubcentric, no wobblies. Nailed it~
    Turlock, CA
    98 corolla 1.8L VE
    I see hubspacer kinda $$$$ but if I get this will good go on rear not front ??
    Added: May 10, 2013 at 10:47 PM
    Mine rim is 6.5 wide maybe try 7 or 7.5
    More for the rear because you need to go wider in the rear to get flush. My front was no spacer at +38mm at the show.
    Turlock, CA
    98 corolla 1.8L VE
    yeah I see ur car @ toyotafest show, I like these looks on ur car body car rim &tire look just about right fender equal.
    Yea it's totally possible to score without them but it's always a good idea to use them.
