What should I do with the Corolla?
Discussion in 'General Discussion' started by JLee, Oct 9, 2008.
    plu Well-Known Member
    SC
    Yeah, it will bolt on. The only problems are that your RPMs will be higher when cruising on the highway without that 6th gear and when you hit lift and shift you will land lower in the RPM bandwidth falling out of lift in your next gear when trying to hit lift again which makes you slower than with a 6th speed. Talk to the spyderchat guys some guys on there have a 2zz with 5 speed.
    change gear ratios on your 5speed? o.0
    JLee TD05 3SGTE
    NH
    I already have an MR2, which is more than happy to take however much cash I'm able to spare...so I don't want to spend too much on other things until she's in the 12s..heh :p
