Washer fluid nozzle
Discussion in 'Care & Maintenance' started by MovieSTAR, Aug 20, 2009.
    Washer fluid nozzle
    nozel? anyway the thing under the hood that you put into the bottom of the thing that squirts out fluid....fell off...or at least i think it did. i pushed it back in with my finger and taped it in...but is there any special way of like twisting it and making it stick in better? or do i have to replace it.
    pics on request since im lazy
    Nozzle.
    What part is falling off? Is it the hose running to the nozzle or the nozzle itself?
    Not much you can do about the hose - as it probably is dried out and not making a good seal. If there is enough extra hose, you can clip off the end and see if that helps. A quick solution is to run a nylon zip-tie around it temporarily. That rubber hose should be pretty cheap - so I'd just replace it and be done with it.
    its like the part that goes into the underside of the nozzle thats falling off i sorta taped it on and it works...thinking i can glue it on or something. the hose looks fine...i think i sprayed some washer fluid into a body panel in my car and whenever im driving i hear it swishing around.
    Ares Active Member
    Houston TX
    pix would be nice.
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    I have like 6 of them sitting in my storage from corollas ive ripped off at the junkyard if you want one
    ill give you like 5 bucks for one?
    the piece is taped in
