Vibration issues
Discussion in 'General Discussion' started by 93geoprizm, Feb 1, 2010.
    93geoprizm Active Member
    Vibration issues
    Yea i know guys its mostly due to bad motor mounts, wheels not balanced properly, tire rods and stuff. This I ahvent really baan able to understand. So basically the vibration come in at 55mph to around 65. First thing i thought, wheels need to be balanced. Got those done and its still there. I was thinkin if it motor mounts, it should vibrate a lot earlier and harsher. Any idea what it could be? Below 55 i dont feel any vibration
    nyrican52884 Active Member
    Plymouth, MA
    Could be a wheel bearing or cv joints also.
    Ares Active Member
    Houston TX
    I have this bad on the ae82. I think it's a number of things with my car:
    on the front wheels, 1 stud is missing it's nut (both left n right)
    the back passenger wheel seems to be wobbling, ill remove the wheel and re-seat it and see if that goes away
    I will probably put the 13's on and see if problem still there.
    One thing for sure, if problem persists, insult your tech.
    I had recentl put in a rebuilt axle on the drivers side. Passenger one is the stock OEM. Just had my alignment done and its still there. i give up. It minor but was just bothering me, oh well
    step 1: do a search
    step 2: read about the hundreds of other posts on this same damn subject
    step 3: ???
    step 4: profit.
    but since youre too fucking lazy. Its more than likely (like a 99.9999999% chance) your wheel hub/bearing misaligned.
    motormounts would only really be noticeable if they were semi-bad at an idle, and if really bad, at every speed.
    THE TOYOTA KID New Member
    Galway/Ireland
    My sister had that problem in her Altezza and it was her Top Wishbone arms that were gone...
    MacPherson strut my man.
    Ares Active Member
    Houston TX
    Fixed my problem. It turns out the the front tires were so bad. They had camber damage from the old spring/strut setup. The rear wheel is so unbalanced that you cant make it roll and stay up.
    My advice:
    check your rubber
    balance
    align
    also make sure wheels are on at the right torque specs
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    Also make sure a belt hasnt shifted or seperated in a tire. that can do some damage
    I check my rubber, but it's not the one that belongs on the car. :D
    i had this problem on my Corolla but it turned out one of the wheels was out of round.
    Ares Active Member
    Houston TX
    This happens lots on small trucks or SUVs with like road tires. "Cupping" I think is the term when the tires get bumps etc.
    JrollaS Member
    Lancaster, Pa
    Yes cupping is the term and it is usually more noticable when the tires in the front are cupped real bad. when they are in the back it is much harder to hear or feel so if your tires in the back are in better condition and you dont have money for new tires just put the better, smoother tires up front
    SaberJ2X Lurk MOAR
    Mayawest, PR
    I had it mine, the vibration at those speeds, turned out to be a wheel bearing in the REAR
    yes, but i'm talking about the actual WHEEL, not the tire.
    Ares Active Member
    Houston TX
    o sh!t, no way. I doubt potholes would be the culprit for that, or are they?
    Oshkosh WI
    Cupping or Chopping tires are caused from worn out suspension components and also lack of tire rotations. We get them at work all the time and some are really bad. Today we actually had a 95 prizm come in and the rear tires were so out of round it felt like we left a wheel loose. When we lifted the car up i could literally lift the whole strut. It was really weak. And they had really cheap walmart tires on the car so they wore out fast.
    FWD cars usually have chopped tires in the rear. Rear wheel drive cars usually have it in the front. Its basicly the tires that arent doing anything but rolling.
    You can have a wheel be out of balance by either having a bent rim or having tire belts out of whack.
    could be. i have no idea what caused it in my case. might have been a pothole.
    thanks for the fuckin help. Next time youre havin a bad day, try jumpin off a cliff, its simple, short, and painless
    As for everyone else, the tires are fairly new so didnt look too much into the tires and dont think any of the wheels are bent or cracked, otherwise discount tire wouldve told me while doing the rotations.
    Next time you make a post so a god damn search.
    You twit i DID do a search and wasnt able to come to a conclusion, hence i made a thread. No ones askin you to come in this thread. Seriously the heck is wrong with people, not like im a noob here and just posted this thread for the heck of it.
    1 simple search on TN forums:
    http://www.toyotanation.com/forum/search.php?searchid=2595196
    5 threads discussing vibration problems.
    1. http://www.toyotanation.com/forum/showthread.php?t=322930&highlight=vibration problems
    2. http://www.toyotanation.com/forum/showthread.php?t=287771&highlight=vibration problems
    3. http://www.toyotanation.com/forum/showthread.php?t=271160&highlight=vibration problems
    4. http://www.toyotanation.com/forum/showthread.php?t=293803&highlight=vibration problems
    5. http://www.toyotanation.com/forum/showthread.php?t=296253&highlight=vibration problem
    + lots and lots more
    lazy ass.
    plu Well-Known Member
    SC
    Trdforums is for douchebags. Don't post here if you can't take it.
    meh i dont take shit personally until you start cussin talkin like you own this internet space or somethin.
    lol you tell me to go search and give me some TN links? seriously tho hows that any different than me googlin up and finding random links? Anyways man, i really dont even know why im even in a conversation with you cause apparently the amount of education you have can be seen in this thread. First it was the failfex, now you, and who knows when the next one is gonna pop out. If there are any mods still alive out there, lock this shit
    I'm an ass occasionally too. Grade A douchebaggery. :) But yes. Do a search. Google is your friend especially for general questions of this sort.
    yea i noticed, but you know all those lTN links that dude posted, go look at em, theyre no damn help, i mean its basically sayin there could be a problem here or here or here and thats it. No ones really been able to solve the problem so none of those links have helped much
    I took a look. I had to reset my password since I haven't visited TN in almost a year now. You're right. They don't really answer anything. You want to check if your wheels, tires, and bearings are all in good shape and balanced. Any one of those will cause a vibration. Could be that you hit a pothole and bent the wheel or threw a tire belt out of whack.
    ...wow, chill out, dude. it's the internet. someone says something you don't like, block them. it's easy.
    oh, and who's failfex?
