Forced Induction turbo????
Discussion in 'Powertrain' started by i8urvtec, Jan 29, 2010.
    i8urvtec Member
    turbo????
    im thinking of tuboing my corolla, with a t28 off a det and a cast iron manifold, small top mount intercooler, all I need is where to get injectors, and away to tuned everything, all on a budget
    a t28 off a det $400
    a manifold $400
    intercooler $200
    fuel pump $120
    custom exhaust $350
    greedy bov free (have one)
    injectors $???
    ecu or something to tuned it $???
    I dont want crazy power just maybe if i cold hit 180hp on 6-7 pounds of boost if is possible on a 00 corolla automatic :superconf
    SaberJ2X Lurk MOAR
    Mayawest, PR
    sounds feasible 6psi with no IC and maybe just fuel managing + pump with stock injectors...
    las vegas
    6-8psi is safe and you should be able to use your stock injector on low psi and for tuning go either greddy blue or the greddy ultimate.
    Ares Active Member
    Houston TX
    low psi = no kaboom
    pedro is on automatic and he said he only rebuilt his if I remember correctly.
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    I think 6-8 psi will definitely put you closer to the 200whp mark for sure lol...
    Liquidgsr Well-Known Member
    could you possible use a FMU? I have a friend who runs one on his turbo setup in his 5.0 automatic mustang with no problems. Just watches his oil, boost, and has a wideband air fuel ratio. Would injectors from a celica work or does that have the same cc's?
    i8urvtec Member
    idk I was thinking of supra injectors but idk if they fit
    JDMjody VVTLi > VTEC
    RIVERSIDE, CA
    04 Celica GTS
    get injectors for MR-S.
    Power EnterpriseUSA.com
    forgot the cc size. 560 or something liek that. mite be bigger
    idk they still have some?
    1zz engines
    i8urvtec Member
    thank's but is that the price of each one or all four? and also can I use there vvti controller to tune?
    nyrican52884 Active Member
    Plymouth, MA
    If you're trying to gain horsepower on the cheap, don't do it. Unless you are willing to do it the right way with good parts, you will have many problems.
    i8urvtec Member
    I think im using decent parts like garett t28 or t25 and greedy bov and power interprice injectors there are no cheap ebay parts there but thanks for the advice, im also thinking of using the t25 bb of my sentra and upgrade to a gt30 for my race car and the t25 for the corolla
    pnyk33 300whp 4afte
    orlando,fla
    88 supra`s 440cc will fit.
    Plymouth, MA
    ^^^ He knows what he's talking about
    You should look into it.
    Centrifugal Superchargers require little addition parts for a basic install and can be cramped into relatively small spaces.
    1.) Pulley
    2.) Supercharger belt drive
    3.) 255lph fuel pump
    4.) Engine Management
    5.) Custom intake pipes
    6.) Oil drain hoses
    7.) Modified oil pan OR you can modify the one you have.
    8.) Need to modify your engine's oiling system so the supercharger gets oil and drains
    out, into the modified oil pan.
    9.) Leave your fuel system in return-less form because it will increase pressure on the
    delivery side.
    10.) You do not NEED to add a bypass, but should just to be safe.
    that should work for you.
    I use that to turbo my nuclear power plant at home.
    You are a really strange dude, no offense. You have the weirdest responses. Sometimes hilarious, but this is kinda weird.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    :D even @ 2psi it would blow the 1zz down like a bad balloon :D
    hmmm, isn't psi psi? regardless of the size of the turbo LOL? I think 2 psi from that thing would be the same as from a small turbo. Maybe 200 psi though...
    SaberJ2X Lurk MOAR
    Mayawest, PR
    psi 2 in a drum is more air than 2 psi in a bucket....
    I think this was both hilarious and weird, with a whole lotta win thrown in.
    more like 0.25 lol.
    Sorry to burst your bubbles, but the 1zz couldn't even displace enough air to move the turbine a millimeter.
    x2
    you should see the myspace photo comments he was leaving me, i had to DELETE, BLOCK, and wash my eyes with soap.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    hence the
    Really? LOL I should add him then :D
    I think you need to read up vortechsuperchargers.com and get knowledgeable. There is a difference between a zoomed in picture and actual size F.Y.I.
    I don't think you and I are on the same page. I'm talking about this.
    I know my way around forced induction just fine. ;)
    Maybe he didn't see the people?
    haha is that you in the black?
