toyotafest 2013... fuck you toyotafest!
Discussion in 'Shows & Meets' started by rx7rocket2005, Feb 11, 2013.
    lol Owned.
    So how's the ride with the new springs in the back? How much camber can you run now? Did you need anything special to swap the springs?
    Thanks bro!
    I don't bottom out now im -7 camber in rear and I just put new tires actually still at America s tire now, no I did not have to do anything special. To fit the new springs just preload em properly most coilvers run same spring diameters and such
    How much preload are you running? Have your ridden in it yet? Did you set preload before putting it on the car?
    Yes I preloaded it before as the instructions on new springs suggested 1nch which is supposedly 72additional pounds of pressure
    Hmm, that seems a bit low, that comes out to like 1.2 kg/mm. Could you link the part number on these when you get back?
    ima go work on my car in a bit ill check the spring #
    If you can do -7 degrees, this sounds like something I want to get. Was it comfy on the way back?
    no its tolerable at best stiffer than ksports for shure1
    Fucking brutal.
    i can hear the mats in the trunk flop arrpund
    Yep, that sounds like it readjusts the spine.
    yeah I toned it down a bit yesterday lifted it a little and set the coils to less stiff in aint show time yet! :isee:
    No problem at all with the inside of the tire now right? I really think the sweet spot for this car is 4 kg/mm spring that is 1/2 to 2/3 the length of the stock one, just so it can clear the inside of the tire.
    no rubbing at all im tucking up to about half of my sidewall on a 205/50/15 tire
    Added: Apr 13, 2013 at 12:15 PM
    gonna re-adjust the rear again today want to make it sit perfect
    Got my show wheels in:
    Work Rezax V1 in 17x7
    Good looking springs there, what are they?
    Sounds like my BC V1 springs set on full hard - spine adjuster, then again, we do not have such awesome roads like you in the US.
    James: them rims look Awesome.
    So what you doing with the white ones now? still going black?
    Thanks Captian!! ,)
    Oh, the white ones are staying white for track use until I'm out of 16" semi grippy tires and then I'm selling them :fyeah:
    :please:
    Ok so how u norcal guys come down , are we meeting up before hand , they will mix it up with the newer gems if were not in some kind of group
    You guys think if i roll down with a camry badge on my accord I can fool them?
    . They are eibach race springs , I guess they sell em as options for their coiloverkits
    I say lets meet up at some parking lot before the show to roll together
    there was an instance where someone brought a 80's celica with an s2000 engine in it, no one was hating....
    Just swap out the H badges with T badges, paint your wheels the same as Mack's, and no one will know .......
    the only thing tho the queen mary is kinda isolated so there isn't any meet up spot close by. closest locations would be somewhere in downtown long beach.........:rolleyes:
    If I go.. I just know its going to be a PITA driving through the city.
    *shakes head*
    James and Irvin and cBass are driving down to my place, and we're gonna roll 4 deep to LB, we should meet up with Ryan and RX7 if we can
    Mrcorolladeaf DEAFNESSCREW
    Turlock, CA
    98 corolla 1.8L VE
    Can't wait go Toyotafest 10 more day to go woot!
    Still debating on going without my hood
    What about me?
    :deskflip:
