Engine Top Horsepower
Discussion in 'Powertrain' started by RexPelagi, May 15, 2004.
    wi rolla Guest
    I dunno, I sent out my money order on the 12th so I hope it will be here any day soon!! :D
    Blk03Corolla Guest
    I currently own the title right now:) Should be some guys catching back up quick though........ you know who you are.
    wi rolla Guest
    Blk03Corolla...I have you beat....... 8) ....I cant wait til i get my header (whenever that is) so I can run my 15.6....watch out XRS owners.
    APC_MATRIX_ Guest
    Or passing by all together :twisted: I'm hoping for 250WHP on low boost and 400ish on high boost (once rolling so that the tranny doesn't throw-up on me, lol).
    APC_MATRIX_ Guest
    Actually, I am pretty damn sure that Tyler has the most HP with a S/C Rolla right now seeing as he has every mod possible plus a 9lb pulley that the rest of you don't have :wink:
    No offence, just saying what I think after reading your sig, there is no way you have more power than Tyler.
    Blk03Corolla Guest
    I do believe I have about every bolt on part for hp the only thing I could go is engine work but dont think im ready for that step yet.
    APC_MATRIX_ Guest
    I know, that's what's scary :lol:
    *cough* LSD *cough*
    03charcol Guest
    sf turbo
    i got 176 to the wheel with the sf turbo no more scanner plus it an auto as soon as i get a scanner i will post dyno sheet the only junk thing is that its at 10 psi or my boost controller says its 69 kpa
    Blk03Corolla Guest
    well its good to know I am still number 1 :)
    crovax New Member
    damn ur only making 176 to the wheels at 10 psi? are you not intercooled or something? I must be making something very close to that with only 6.5 psi... or maybe i'm way off there but i've gotta be close to that judging by the cars i've raced and beaten. (i'm an auto too btw)
    03charcol Guest
    well what extra mods do you have i have everything stock except the turbo and thats it.....no injectors no exhaust..
    bewildered_spruce Guest
    i remember reading somewhere that Toysport can intercool the TRD supercharger... u should look into that, and if it's true then u could make tons more hp :twisted:
    i know thats the only way id go with the s/c
    APC_MATRIX_ Guest
    It's possible, but just get the water injection cause it is probably $2000 less than making a custom air/water IC for the TRD S/C and it cools the charge enough for the S/C.
    That's just my .02 though.
    yeah water injection should do the trick, anything to run higher boost
    i still wouldve liked trd to make it so an intercooler were possible though, too bad they didnt go with a centrifugal s/c but oh well :roll:
    APC_MATRIX_ Guest
    That's what I'm going to do after I build up my motor this summer and next :wink:
    crovax New Member
    dude...ur running 10psi without any kinda of fuel mods? you do realize that if you turned the boost down to 7psi you'd probably gain hp. You must be running soo damned lean...ur gonna burn that up. I Run lean at 6.5psi because i have stock injectors...i'd turn that down, you're definitly not gaining any power by having it up that high.
    And btw, i have a 2.5" pipe comin fom my turbo
    03charcol Guest
    nope its running kinda rich i have the charts for that too....i think need an exhaust to free up some more horsepower and right now its running fine i have two settings 6.5 and 10 psi
    crovax New Member
    I dunno man...i guess if you have the chart, but i dont know if i'd believe that. First off, if the injectors were really that big, TRD wouldnt have included a 5th with the blower. It doesnt make any sense to put 200 hp injectors on a 130 hp car, and at 10 PSI, I'd be making somewhere in the neighborhood of 220-230 wheel hp...if you're only making 174, you're either running extremely lean, or you're not making that much boost....or you dont have an intercooler in which case you should turn the boost down anyway.
    APC_MATRIX_ Guest
    Yeah, 10lbs of boost and 174WHP is lame. Rick (raamaudio) had a turbo charged Matrix and he was running 12lbs at almost exactly 250WHP. He was at 200WHP around 7-8lbs of boost.
    You are getting robbed of power somewhere, very badly.
    03charcol Guest
    crovax i wanna see ur dyno sheets
    crovax New Member
    Blk03Corolla Guest
    I would like to see some accurate dynos for myself too lol
    sean2sean Member
    so cal
    i dont know wuts my whp.... never got it dynoed...
    but at 11psi with a t3 garrett w/ super 60 trim... i can stay head of a s2000 from rolling @ 30mph ... and pull on a mustang gt rollin at 15mph... i can keep up with a wrx from 60-100, but after that... my speed limiter kicks in... and i can pull on a new manual v6 accord... from a complete stop... he chirps his tires from 1-2 and 2-3... his sounds fast... but mine is faster...
    im not sure bout the other guy... but what turbo does he have... runnin at 11psi? if its a smaller turbo then its gonna make less power...
    bzzsan Guest
    ....really?? those are all relatively fast cars...i mean like low to mid 14 sec 1/4 cars stock except for the accord if its a sedan...but if it's a coupe is a low 6 0-60 and mid 14 1/4...if your car can do all that, thats pretty cool especially for a auto..even though you list the first three from a roll so the tranny doesnt matter that much.
    CorollaX Guest
    stock i had 130.. but with all my mods... TRD filter TRD exhaust 19" rims.. i think i have 110 HP now.. hahha car feels so heavy!!!!!! LOL i think i have the lowest HP in here!!!
    RollaS New Member
    it's not your hp that went down..........your weight just went up too much. 19's are killer.
    imported_m120004 Guest
    Im just 14 but im very good on moding 03 Corollas i squeezed out 190hp with a highflow air intake its stock but is better than a CAI ask me how to do this plus i also put in a Borla catback unorthodox race pulleys EL headers and some other secret stuff but i will tell you this all this mods give you much better fuel economy and yeah i put in real good spark plugs
    sorry but i think im gonna have to raise the bs flag on this :roll:
    on another note, Tyler u need to get ur car dynoed again but by somebody who knows what they're doing. i really wanna know how much power ur puttin out
    dominator 04 Rolla 5spd.
    14?! :? What is this special highflow air intake, which amazing spark plugs and what's the 'secret' in producing any more than 160 HP with your mods?
    pkpss Guest
    What are you talking about. This is the Corolla prodigy who is going to mass produce the secret stuff. :p
