Forced Induction To much torque
Discussion in 'Powertrain' started by pnyk33, Sep 4, 2008.
    Legit01Rolla Active Member
    damn rich boy
    mooreofit New Member
    houston
    toyotaspeed90 New Member
    Bellingham, WA
    looks like the cam broke at a weak point due to how the FE cams mesh together.
    I would be more concerned about what actually caused the break -- I say this because it had to have twisted at the gear and not at the cam for that to have happened. It looks more like a "shear" than a break.
    Further, I know you're using GZE pistons -- the cutout angles between the valves and the pistons aren't the same, you should check to ensure you have good compression across all 4 cylinders. There is a chance a valve bent by cranking the engine (doubtful) with 3 out of 4 cylinders valves not moving -- there's a chance one was open fully and a piston met it. (if you've previously done a test to ensure that the motor is non interference then this wouldn't be a problem). Yes, an engine can run with a bent valve.
    Also, in reference to the previous post -- the amount of money you make greatly depends on what the cost of living is in that area. If you make $50,000 a year but the average cost of living (due to housing, etc) is say $40,000 a year then you're not doing so great (not directing this at anyone....). For instance, if I made what I make in Texas I'd be the rich guy on the street. Where I live it's just average money.
    houston
    you make valid points.:D i do live in texas:D and i do alright. i have a degree but i choose to work in another field outside so i can live the lifestyle I choose.:D i could make more money but i make enough and its not worth getting stuck inside a building all day.
    as far as the cam goes i would imagine it was just a poor casting that lead to its demise.
    also i would love to talk to you about how you got your ge head to run on your fe electronics and your distributor.
