Ticking Noise
Discussion in 'General Discussion' started by rubenscorolla1998, Feb 1, 2010.
    rubenscorolla1998 New Member
    not 100% sure yet. but it broke down and will not turn on. a couple of people that listened to the engine noise before it died said it was a piston. when i get a chance to open the head i will find out. but right before it died the engine sounded like it was going to blow up!
    Should of diagnosed the problem before you decided it was safe enough to drive. I personally wouldent drive if the engine sounds like its going to blow up.
    It didn't sound like It was going to blow up. It only made a ticking sound. It was only after the car stalled at a red light. I pulled right into a gas station. And when It started up one last time and that's when it sounded like it was going to blow. So I drove it for only two weeks with the ticking noise. then on the last day is when it sounded really bad. And I was trying to find a mechanic for cheap who would look at it. I was going to take it to toyota but they wanted $100 per hour. That's a little too much.
    Well trying to go cheap is going to result in you having to get a new engine now perhaps.
    darkgamer1912 Member
    CT USA
    did u have oil in ur car cuz that could of been it if urs was leaking at the chain tensioner like mine is ur motor was problably losing oil and it just couldnt lube any of the parts. so something broke. but im still convinsted the ticking was from the pully tensioner something else might of gone wrong with the motor.
    I wasn't trying to go cheap. Just going with what I could afford. And more than 2 mechanics said it wasn't the tensioner
    You cant win... just stop... its over... :D
    I didn't know I was trying to win anything. Just stating the facts
    Everything is a game to Hummer. Don't mind him. lol
    So what are you going to do now?
    Des Plaines, IL
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    Not sure yet. Ill be replacing my belt tensioner in about a month wen the engine comes out.
    That is absolutely not true, and is a false statement. I reject you sir.
    I got rejected. I feel special. :)
    well im searching for an engine. searching all of south florida for the best price. and i found a guy who will swap it the same day for 500 bucks.
    Des Plaines, IL
    I may replace mine too in about a month when spring break hits.
    Glorious answer comrade
    Cool story bro.
    Isent the ticking noise from the PCV valve?
    :CSB:
    That title goes to me now. As the only active member with a full 7 piece authentic (you hear that cBass?) TRD kit
