Thunder Hill with Norcal Racing Club
Discussion in 'Race Track' started by James, Feb 3, 2012.
    I wanted to bring the body kit rolla that one time i went to help you on the axles to show you, it was a bad loud bang, i tried fixing it but got tired of it
    Its cool tho, ill eventually buy some new coilovers before toyofest
    Installing rears on the corollas? man what a horror story i had with them, haven't told anyone of you guys because i would feel a bit embarrassed....
    just post it up! I won't say anything I promise. Or LINE it.
    maybe next time i see you or something.
    Just fucking post it please.
    No pressure! :D
    Speak for yourself.
    :thumbsdown: nope, all i can say could of lost my fingers
    We've all done stupid shit
    Hella old like received ~
    Did two things: clutch start switch delete; figured out proper low pass filter settings on the amp.
    Win.
    About to take apart the interior so I can wire in my aux connector, fix the stupid latch on the cubby (#8thgenproblems), and install my standalone/J&S safeguard. I'm contemplating running nitrous (75-100 shot) for a little while for fun before putting the S/C on to test out the J&S safeguard and compare it to the PFC's own knock retard abilities with Copilot.
    I know the feels on the amp, I did the same a couple weeks ago
    Update: started the car to keep the battery alive. Ran it for 20 minutes, all seems well :)
    Ran it in place or actually drove it?
    In place for 10, drive around the block. Alignment is so fucked, the next > 1 mile trip is to get that done.
    From boss-like suspension upgrades?
    KSport...... Not sure if boss-like or troll-worthy. :okay: :ok:
    Nice ! :thumbsup:
    I am gonna need a alignment soon also when my bump steer kit gets in
    Very curious, please do tell!
    The bump steer gets so bad on this chassis, :(
    JEANIOUS!!!
    I didn't really know I could mod this sort of thing, thanks.
    No problem !, I am working a lot on suspension and dialing in i really need to figure out a rear roll center adjuster .... maybe overkill but worth it
    Ok so the top is what your tie rods should look like, and the bottom is what your tie rods look at about now.
    So Flipping the tie rods to the bottom should reduce a majority of the bump steer, but to get it completely reduced you would need custom end links that are extended even lower. so it would be flipped and lowered 10mm to get the most out of your steering.
    So you'd already done this?
    I flipped them yeah pretty easy to do
    Hmm. I might look into this. Me no likey bump steer.
    So did you need the AW11 kit to flip them? Gonna do this today. :)
