The DEFINITIVE interior/dash lighting Q & A forum!
Discussion in 'Interior' started by Miguel, May 5, 2004.
    toyotaboy New Member
    lith, IL
    nah, i figured it out.. turns out you can unclip the whole assembly, pull off the connector, and slip the light out with a screwdriver. I ordered a few different ones for trunk and dome light.. So far the trunk ones aren't very bright (I expected more considering how bright some of the hyperLED's get), but I'll experiment. Haven't installed the dome one yet because last time I tried I sparked it and caused my fuse to short.. so I have to get some more fuses before I try it again. The couple seconds it was on though, didn't seem so bright either (two LED's don't cut it).. Bought a xenon bulb to try out.
    CaptainCorolla Thread Captain
    Orange County
    Yeah, I've had dome light issues before myself. I find it's best to turn the switch to off and close all the doors. For some reason, even if you don't have "door" selected, the dome light is still part of the door circuitry.
    Orange County
    ArdotheWan New Member
    Torrance, cA
    Be careful with the A/C button guys, I have messed mine up somehow and it doesn't work anymore when I press it. Tried a million things to fix it too. Look in maintence board for my info or if you know how to fix these things ;)
    Orange County
    That's always a fear of mine more than anything else. Can't go w/o A/C in SoCal. I was reconsidering tackling that mod this weekend. I did some car work though, got a power steering flush, coolant/rad flush, new thermostat and engine steamed.
    Orange County
    When you replace the shifter light in the center console, is it necessary to remove the rear piece (rear of the shifter) only, or also the large front piece?
    Torrance, cA
    Ya you got to have the A/C. I use it at night even I'm always hot. Also I hate getting my hair all crazy with the windows down =p
    rollarace New Member
    Blue Bell, PA
    Wire diagram for foot well neons...pls?! :D
    I want to put the neons there and I don't really know how to wire that well but im gonan try this I've gotta start somewhere! I was going to use the power from the cig light...I've got the 99 CE model...and I'll need to wire in a switch so add that to the pic for me. Thx :D
    Blue Bell, PA
    I saw there was a DIY on putting in a trunk neon...I did it and he thought it looked h0ot so I told him how! Now none of his door or map lights work now..I think he blew a fuse ..soo my question does anyone know where the fuse bow is on a 02 LX civic or what might have happened? thx
    Orange County
    Ok, so I tore down the majority of my car interior last night in an attempt to put a finish to this project...
    First off, anyone that can replace those A/C button lights is a god, seriously, I couldn't get that fucker out.
    Second, the bulb for your automatic shift indicator is a #74. To get it out, you only need to remove the rear center console piece (armrest and storage on some models). That's easy, just remove the two screws in the storage and pull off the unit. The bulb is right at the back of the shifter area, so I used pliers to pull out the bulb and socket. Replaced it, and bingo! Everything is done now, except the A/C button and the window button on the door panel, that would require soldering.
    juggaloryder Guest
    This is awsome, cause I've been staring at those lights wondering what I can do to "fix" them... and make 'em blue to match the damn car...
    Josh
    Miguel Guest
    Ac button you need to pop off the main cover then take out the main climate control component and unclip the ac body it unclips from some wires and from the main climate control. you can either wire in a Led or use the existing dolder and build an Led to that.
    juggaloryder Guest
    I've got a question, I was gonna go with the indiglos in my gauge cluster, but now I'm thinkin that stock with blue back lighting would look better, and match the paint better, can the bulbs back there be changed, and is so what bulbs do I need?
    Josh
    Torrance, cA
    I got that part of the light changed by wrapping a LED in the old like bulb stand and taking that bulb out. But I was too scared to change that 90'angle light that turns on when the AC is on.
    Orange County
    I pulled off all the trim and took out the screws for the climate control unit, it came out about 1 inch, then stuck. Screw it. Looks good on you guys cars though! Good job.
    Orange County
    Juggalo:
    Check out the LED website in my signature, they sell a wide angle 194 LED bulb. It's still not as good as standard bulbs, but better than most LEDs. I use those with my indiglos. You will need 3. I had the colored glass ones for about a week, they looked indiglo green, instead of blue, but still nice. Now everything is ice blue LED. Where are you now? Still in SD?
    Miguel Guest
    Yes they can be changed the bulb size is 194, but the problem I had is bright spots, you would have to shave down the led to recieve even lighting. or you can use regular bulbs from Advance I used red and they came out great.
    Fox New Member
    Under your sink.
    sorry to get outta the subject guys... but miguel where did you get that kickass reverse indiglo on yer car?
    and how'd u change yer clock display color?
    Miguel Guest
    I got the Gauges on ebay for like $20 bucks
    These are a bit differnt then mine but in my view nicer. http://cgi.ebay.com/ebaymotors/ws/e...sspagename=WDVW
    The clock display needs to be unscrewed an unclipped from the main center console, and then sprayed with 2-3 light coats of stain glass spray paint. They sell it at craft stores like Michaels. Ive only seen it doen in red. but becareful don't spray to much on b/c during the day it will be harder to see the time. Good luck
    Fox New Member
    Under your sink.
    thnx for the info miguel, i've seen those reverse gauges befroe don't actually like them... the ones you have are the best i've seen yet, but they seem to have tun outta production.
    juggaloryder Guest
    MCAS Miramar. For 40 more days. Then, Fallujah, Iraq...
    Josh
    Orange County
    Torrance, cA
    at some point im doing a DIY for this stuff. Took pictures of an unassembled AC part thing I bought.
    Just have to get around to it
    Orange County
    Excellent, you know where to post it. I might be getting a digital camera this week, fucking finally. I'll post some pics of my car lit up at night. Also, in other news, with my newest promotion, I now get to park indoors at work, no more dirty car.
    Torrance, cA
    it might not be the most in depth DUI though cause i forgot to take pictures of the circuit boards in the AC controller and the rear defogger piece and i dont know if ill have the energy to reopen it =p
    dont expect the dui till next week though gonig camping this weekend!
    Orange County
    Torrance, cA
    hadn't had the time to do the DIY (school started) but i will i promise!
    Orange County
    It's all good, I JUST got a digicam, will be putting up pix shortly.
    Orange County
    Orange County
