sub is making weird noise!help!
Discussion in 'Interior' started by phal99, May 20, 2007.
    phal99 New Member
    check your ground wire if it's grounded properly
    GTurner598 Guest
    i just recently installed a 12 inch sub in my 03 corolla S. It seems like it is picking up some kind of frquenct becasue when i start the car and i turn the radio all the way down it rumbles. I have ripped the wiring apart 3 times and tried to find whats wrong. I have the ower wire run on one side and the rca cable on the other side.Any help would be great.
    GTurner598 Guest
    I tried all different grounds and none of them worked. I also bought new RCA cables today and put them in. I got a thicker wire than i previously had and it still rumbles. Any body have any more ideas.
    Is the sub new or used and what brand is it? List the specs.
    GTurner598 Guest
    It is a brand new sub. power Acoustik FUBR. it is 1800 watts and 800 rms.
