So what could be causing this noise?
Discussion in 'Stop, Drop & Roll' started by MacktasticSlick, Jan 2, 2010.
    It's not that good of a movie, but my car has a bad sound every time I go over a speed bump like this.
    JDMjody VVTLi > VTEC
    RIVERSIDE, CA
    04 Celica GTS
    wth is that?! lol
    idk tire rubbing or shocks bad.
    plu Well-Known Member
    SC
    Sounds like the 3 strut nuts on the front are loose. If not, you got bigger problems.
    Well it's not a tire rubbing, I know that. lol. So, what is a strut nut, and how can I check that? I'm a dummy when it comes to car stuff, I'm using this car to build my knowledge. I'm gonna make a different video, from a different angle, to capture the sound better. So, what kind of "bigger problems" are we talking about?
    SC
    It's the 3 nuts on each strut a strut bar would attach to. It sounds like your strut mount is loose so you should check the tightness of those nuts.
    bigger problems means you will have to jack up the car take off the wheels and look under there.
    Those are the ones under the hood right?
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    Ok that's what I thought it was thanks guys I'll go look at that right now... Didn't think those would ever come loose lol
    whydontyouchoos KFM
    Phoenix, Arizona
    sounded like my car just a little when i had a bad strut :(
    Well I have like 74K miles on all original suspension, so maybe that's an issue too?
    Ok made a second video from a different angle, this captures the sound better than the first one.
    RIVERSIDE, CA
    04 Celica GTS
    sounds like bolts loose.
    mite need replace shocks/struts.
    you should move down here. lol
    Man I used to be in San Diego, I'm gonna be back there within the next year hopefully. :D
    RIVERSIDE, CA
    04 Celica GTS
    long time..lol
    hate SD hills and awkward roads.
    whycant they be straight like in OC. hahaha
