slammed 03
Discussion in 'Pictures & Photography' started by j0relle, Sep 21, 2004.
    j0relle Guest
    slammed 03
    i still have to put my grill in.
    did away with my tein cut springs.
    heres a list of what i have new on the car.
    1. ground control coilovers
    2. koni yellows
    3. hotchkis rear sway bar
    4. short ram intake
    5. WRX st0ck rims
    6. altis grill
    7. jdm headlights
    8. ebc greenstuff brake pads
    the estimated clearance on my ride from lip to ground is about 1.0-1.5"
    chr0me94 Guest
    Are you able to make turns without rubbing like crazy?!
    Shifty SIdeways Noob
    Memphis,TN
    thats not slammed enough!
    sxlostv1 New Member
    Los Angeles
    that's the biggest tein sticker i've ever seen
    j0relle Guest
    Prodigy3006 Rubber Man
    Alabama
    howd you lower it? just springs or an entire coilover kit?
    Corolla DX-R AE100
    Vancouver, B.C.
    hahahaha me too... that is big...
    rollaracer4 Guest
    i think its just the tires that make it look so low... and yeah thats a huge sticker ... look at mine
    93corolladx Guest
    I say drop the sticker but the drop looks amazing.
    j0relle Guest
    springs. =D
    j0relle Guest
    believe me, i tried the stock matrix xrs rims on it, it looked the same, just a bit higher but a much great TUCK.
    j0relle Guest
    im able to turn, juss a bout 2cm away from "rubbing".
    as for the u-turn, i cant, i hear it rubbing the fender well. slammed enough..?
    vash Guest
    Damn Thats A Big Sticker
    rollaracer4 Guest
    do you have the s-techs cuz i do and mine does not look that low!
    what kind of tein springs do you have dude....because that is low
    04SType New Member
    Jorelle, did you do these yourself? If so did you cut the bumpstops or did you leave them stock?
    LowRolla Will work for turbo
    Oviedo, FL (orlando)
    he HAD to have cut them - i have the s.techs and larger rims, and mine is nowhere near that low. (my sticker is a lot smaller too lol:(
    looks NICE though man. im not sure how you could possibly drive down here with all the construction and speed bumps... but seriously looks good.
    SSJ_Rolla Guest
    I think i have 2 agree with LowRolla those springs have to be cut, I think I had the S.techs on for a long time and my ride doesnt sit that low
    808VIPROLLA Guest
    yes, his springs are cut. however jays car is pretty nice, just as low or maybe a little lower than mine. But his car is pretty nice, he only nees some nice rims.
    04SType New Member
    I have the Tein springs on mine too and mines not that low, Hmmm. I didn't cut the bump stops though I left them the stock length. Rides fine..
    fastrolla96 speedbumps..yum
    Oklahoma
    Man thats low! But not as low as I am ;) Looks really nice man.
    yellow rolla New Member
    in boring ass charlotte, NC
    thats got to be a horrible ride, doesnt it bother u when u scrape everything in sight?
    j0relle Guest
    cut. =D
    j0relle Guest
    stech. cut. 2 coils rear. 1 3/4 front.
    j0relle Guest
    the bump stops in the front are cut half way, as said so in the tein instruction paper thiugy..then it was still a bit too high for me so we cut the springs. the ride is stiff, if the road is jacked up, u will BOUNCE [minorly tho], if the rooad is perfect, it rides like stock, if not better and smmooother..
    j0relle Guest
    wells u got rims, im using my stock tires and stock 15z. i bet id be on the ground if i put 16z w/ lower pros. right now, i cant even clear most bumps [which are like 2-3inches tall].
    j0relle Guest
    trim ur front bumpstops to about half. it should go down about 1/2 - 1/3 inch more.. heck, take them out if u wanna goo lower. =D
    j0relle Guest
    thanks for the compliment bro..mannn i wsh i could afford rims..but for now, i like the way the car is..maybe later on..=D
    j0relle Guest
    i think i deserve to keep ur screen name now. lmfao. keeding.
    sorrie for so many replies, im too damn lazy to copy and paste. =D
    Oklahoma
