should i get headers?
Discussion in 'General Discussion' started by ExDream, Aug 8, 2010.
    ExDream Member
    SoCal
    just wondering what your opinions on headers are , so who has em!?
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    everyone is going to tell you porting your stock exhaust manifold would be the best option without consequences. Some will tell you the OBX header is junk because it cracks. Most of the people that used the OBX or forza header welded in a flex pipe and had no problems. Its all personal preference. I still have to put on my forza header :)
    alby13 New Member
    what? porting a stock exhaust manifold is a waste of money.
    Getting an after market header for a car that maxes out on 120HP without a turbo is a waste.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    agreed port stock header...
    you might even get more mpg out of it cause of pumping efficiency improvements
    from the front side, there are some lips in the holes, and in the down-back side when all the pipes come together, there is usually a BIG ASS weld mass thing in the middle, grind that down...
    IF by any reason afterwards you get exhaust leaks, weld on the outside, and grind some more in side then to make it perfect.
    its_ikon FIRST widebody
    Henderson, NV
    just get a header. you don't need headers
    heeeheee
    las vegas
    agree,headers is for v6,v8,v10 and v12
    Rincon , Puerto Rico
    I got header and I like em :)
    i have an obx. its a piece of shit. the airflow through it sounds like garbage.
    Leave it alone and get a new car.
    don't forget the flat 4.
    JLee TD05 3SGTE
    NH
    I gotta do a t-belt on my FXT today...feel free to visit and help! :p
    nnnnnoooooooooooooooooooooooooooo
    Or rotary.
    ExDream Member
    SoCal
    so going off topic. has anyone installed hotchkis sway bars by them selves?
    JLee TD05 3SGTE
    NH
    awww c'mon now!
    with help, yes. find someone with a lift...it makes things SO MUCH EASIER.
    dude, i didn't do *mine* when it needed to be done. i paid someone else to do it for me.
    Corollaczy New Member
    I did my own sway bars, it not that difficult, but you have to drop the gas tank down to change the rear bar, but to do that you have to drop the exhaust. If you have a one piece aftermarket exhaust then I dont know how you can do it. But I had stock exhaust and I tried to unbolt it but of course the bolts just broke off, so I had to drill them out and rebolt it up. It kinda sucked but the new sway bars are awesome
    las vegas
    i heard boxer engine is hard to work on,just bring it to subby shop and pay extra to get the job done quicker.
    it's not hard. it IS a pain in the ass, due to the configuration. something as stupidly simple as changing spark plugs almost guarantees busted knuckles, even if your hands are little like mine.
    las vegas
    thats what i meant:D
    ok, then actually say what you mean. :)
    I will, troll.
    Shut up hummer
    Lol, owned. Maybe that means ill be driving a lexus some day.
    :scared:
    :scared:
    In other news, I got headerS today! :awyeah:
    Ohhhh that's what was in the box.
