Rear Disk Brake Conversion
Discussion in 'Stop, Drop & Roll' started by Salty_Dog, Mar 20, 2008.
    Salty_Dog Old Fart
    Fredericksburg, Virginia
    Anyone ever do a rear disk brake conversion on an 8-gen Rolla?
    The parts for a AE101 are supposed to bolt right in (if you can find them).
    i did.
    Salty_Dog Old Fart
    Tell me everything. Starting with where you got the parts. Thx.
    I bought the complete kit from Shyguy. He had a showcar corolla in Canada. I don't know where he sourced it from.
    If I were you, I'd go with Dr Tweak's conversion kit. It uses '95 Celica GT rear rotors. All you'd so is buy the $30 dollar rotors and have them redrilled for 4x100 at a machine shop. If you get em from the ae101/111s you'd end up like me, I have to buy replacement rotors @ $200 w/o shipping.
    You might want to get your brake pressure valve replaced since you wouldnt be applying the optimal brake pressure since drums require less pressure to work optimally compared to discs. Most people don't do this tho but I am planning to.
    I haven't checked this board in months... Sorry to bring back an old thread, but does Dr. Tweak still offer this kit?
    should be just pm
    Joeyicu New Member
    i wonder if components of an MR-S would work as a conversion kit
    SD_S New Member
    SF, CA
    I was thinking of the same thing too
    Des Plaines, IL
    I brought that up a while back but don't think anyone has tried it.
    I was almost sure the mr2 parts work from a MKIII but I never tried it either. waiting for a killer deal on parts
    rayray1 Active Member
    But it's RWD. The setup is different. The donor has to be rear disc FWD.
    CDD New Member
    Lost
    Hi
    One model of the Corolla coupe like this photo LINK have rear disc break. Will it fit the 01 Corolla it will be much easier for me to find parts of this car here on the island.
    Thanks
    Joeyicu New Member
    why?
    the front disk setup on the car may work out perfectly, ill have to pull the wheels on my dad's wife's car sometime when im bored and take a look
    I thought of a way to make a super cheap rear disc conversion. you need a 1/2" steel plate to build a caliper mounting plate. then you can use corolla front disc calipers & rotors and you're set. $250 rear disc conversion and uses all stock equipment
    That's the only possible direct bolt on donor. The AE92 GTS.
    I'll be looking at it too. The question that comes up is that the on a FWD car, the drivetrain is in the front and powers the front wheels. Whereas the rear is just trailing. You will have components from the front that won't work with the rear. It could be possible though.
    I'm interested. Let me know how it turns out.
    well I haven't taken measurements but this is a general shape of what the plate would look like. mounts behind the axle hub meaning:
    you need to use the front brake dust cover, need to use longer bolts, need to use torqued nuts to hold the plate on.
    ooh.. autocad. I love that program.. I still need to learn solid works because that is the industry standard for MEs.
    Anyways I say AE92GTS rear setup will work best. It'll bolt right up to the strut and and trailing arm. The problem is in the rear control arms. The AE92 have the bushings built on the hub/knuckle assemble while the AE101/ZZE111 have them on the control arm assemblies.
    However that obstacle can be easily solve by frankensteining the outer AE92 control arms half + the AE101/ZZE111 inner halfs. Notice 2 out of 4 control arms have a threaded turn buckle in the middle for toe adjustment. all you have to do is unscrew the stock outer half's and screw on the AE92 outer half's.
    But you do need to grab 2 more AE101/ZZE111 and AE92 adjustable control arms. This process is all bolt on with no machining what-so-ever.. I think it'll be a good weekend project.
    darkgamer1912 Member
    CT USA
    i have a question y cant you just use the disk brakes from an xrs rolla or matrix isnt the suspension almost identical on the 03 to 08 rollas and matrix
    Because the the hubs are 5 lug instead of 4. If you don't mind having 4 lug in the front and 5 lug in the back, go for it. LOL :D You can always swap the hubs for 4 lug ones, but that involves more unnecessary money.
    He was referring to the 9th generation Corolla, which had a 5 x 100 bolt pattern.
    Joeyicu New Member
    the idea of use ae92 components seems like it would make acquiring parts difficult
    im really digging this using a corolla front brake components to bolt onto the rear, im totally going to take apart my drum setup this week if i get bored
    CT USA
    o yah lol i forgot the rolla came with 5 lugs i guess thats out of the question. what about an early gen celica didnt most of those come with 4 lugs
    Joeyicu New Member
    1986-1991 Celica's had the same bolt pattern
    as do the 85-89 mr2's witch fastbrakes.com sells a rear brake upgrade for, that may be the way to go
    well my idea doesn't work. there's no way you can use the front components because there isn't enough space for installing a mounting plate. otherwise... it would work.
    Joeyicu New Member
    whats in the way the control arm?
    the pots sit too close to the hub so there isn't much meat left between them. the metal would be too thin to support the force of the caliper braking
    I've been talking to Dr. Tweak. The setup would cost 500 bucks + shipping.
    93geoprizm Active Member
    does tweak come to this website??? where is he nowadays? how do u get in touch with him?
    That's my little secret. :)
