Progress Sways
Discussion in 'Stop, Drop & Roll' started by Vibe, Nov 25, 2006.
    the sway bar package come with everything you need in box. Yes they for 98-02. Endlinks you can get from whiteline or many other companies out there.. they're pretty much universal depending on lengths (take off your wheels and measure your stockies). You could even make em yourself with a threaded rod, nuts and balljoint rodends.
    http://www.whiteline.com.au/docs/bulletins/113_links.pdf
    The whitelines ones are somewhat pricey.
    The whole hotchkis vs. whiteline debate could be boiled down to hollow vs solid bars but I believe hotchkis problem is poor material choice and lacking build quality.
    I asked globalperformance about their opinion about replacing the endlinks.
    does anyone know where i can get 8th gen rear endlinks? or know the size specs for our oem one?
    just got my whiteline sways... installing it on monday.
    cant wait...
    The groupbuy on toyotanation has more options for the corollas now.
    AE101; AE102, AE112 94- 11/01 Corolla
    Superpro SPF0996K Front Control Arm Lower - Inner Front Bushing: $23.80
    Superpro SPF1900K Front Control Arm Lower - Rear Bushing: $87.60
    Superpro SPF1901K Front Control Arm Lower - Rear Bushing: $87.60
    Superpro SPF1902K Front Control Arm Lower - Rear Bushing: $87.60
    Superpro SPF2298K Front Control Arm Lower - Rear Bushing: $30.75
    Superpro LP8130 Front Sway Bar Link Complete Rod OE Replacement: pm if interested
    Superpro SPF0832-_ _K Front Sway Bar Mount to Chassis Bushing: $ 12.51
    Superpro SPF1947K Rear Control Arm - Bush Kit: $72.00
    Superpro LP8001 Rear Sway Bar Link Complete Rod OE Replacement: pm if interested
    Superpro LP8124 Rear Sway Bar Link Complete Rod OE Replacement: pm if interested
    Superpro SPF0613-_ _K Rear Sway Bar Mount to Chassis Bushing: $13.24
    Superpro SPF0823K Rear Trailing Arm - Bushing Kit: $14.04
    Whiteline KSB583 Adjustable Front Strut Brace-strut: $135.88
    Whiteline KCA415 Front Camber Adjustable bolt kit-15mm: $56.21
    Whiteline KCA340 Front Caster Adjustable kit - to 7/95 with horiz mount: $52.31
    Whiteline 70389 Front Spring-coil lowering kit - Control: $117.47
    Whiteline KCA412 Rear Camber Adjustable bolt kit-12mm: $49.35
    Whiteline 70416 Rear Spring-coil lowering kit - Control: $117.47
    Whiteline BTR71Z 18mm Rear Swaybar- Adjustable: $139.24
    Whiteline BTR71 18mm Rear Swaybar: $111.98
    Whiteline BTR71XZ 20mm Rear Swaybar-X h/duty Blade Adjustable: $157.61
    Whiteline BTR71X 18mm Rear Swaybar: $111.98
    AE110-112 5/99 – 11/01
    Superpro SPF0832-_ _K Front Sway Bar Mount to Chassis Bushing: $12.51
    Whiteline KSB583 Front Adjustable Strut Tower Brace-strut tower: $135.88
    Whiteline 83107 Front Spring-coil lowering kit: $117.47
    Whiteline BTF82 22mm Front Swaybar: $111.98
    Whiteline 83108 Rear Spring-coil lowering kit: $117.47
    Whiteline BTR71Z 18mm Rear Swaybar Adjustable: $139.24
    Whiteline BTR71XZ 20 mm Rear Swaybar Adjustable: $157.61
    Whiteline BTR71X 20mm Rear Swaybar: $111.98
    are the rear end links worth getting? anything else worth getting on that list?
    i pmed that guy about them..i also wanna know what else is worth getting
    holy moly, i've been waiting on the next group buy.. I just need to get the rear trailing arm and control arm bushings and I have officially upgraded all bushings on my rolla.. those prices are great! Way less than what I've paid in the past. Thanks for posting.
    oh yeah, better grab whatever you want quickly. he said due to currency exchange rates, prices will be going up by april 27th
    by the way, what does replacing the bushings do to handling?
    01rollas New Member
    stiffens the suspension and making it sturdier and stronger also increases longevity of the suspension components. allows for better handling.
    Also polyurethane eliminates unwanted changes in suspension geometry.
    I currently have
    Superpro SPF1902K Front Control Arm Lower - Rear Bushing: $87.60 (increases caster)
    Superpro SPF0832-_22K Front Sway Bar Mount to Chassis Bushing: $ 12.51
    Whiteline BTR71XZ 20mm Rear Swaybar-X h/duty Blade Adjustable: $157.61 (comes with poly bushings)
    and will be getting
    XS Engineering eliminated understeer in their WRX by changing out all rear bushings.
    wait so which ones do you get for the 8th gens =[ im so confused! he hasnt replied to me yet
    the ae110-112 list
    i'm gonna hold off for a while since i'm gonna save up about 800$ for a miami summer trip.
    nice..miami =] im going to europe
    do i need to get any bushings? sry im such a noob at this i feel retarded for not knowing
    you should worry about your body work first :D
    shhh, i know this. MAN
    just got my fsb mount bushing. i just need to unbolt the mount bracket, take them off, grease the inside of my new bushings and slide them on and then tighten the mount brackets back on right?
    [IMG][/IMG]
    yep, thats about it =] lol i dont know probably
