problem wiring new radio...
Discussion in '8th Gen' started by toasterburn, Aug 31, 2014.
    toasterburn New Member
    I'm trying to install a Kenwood radio into a 2000 Chevy Prizm. I bought the correct wiring harnesses and wired everything up, but it's not working right.
    The radio only works if I unplug and then replug the wiring harness. Then I can turn the car on and off a few times and everything seems fine. If I leave the car off for a few minutes though, the radio wont turn on again until I unplug and replug the wiring harness again.
    Any ideas what's going on?
    You sure every wire is 100% in the correct place?
    Yea, I'm sure everything is wired together right because the harnesses came with straightforward diagrams. And I soldered the wires, so no chance of a loose one.
    guess the radio is bad?
    Do you still have the stock radio to try out? That should isolate the problem to the car's wiring or the new harness and radio.
    FriskyDingo Well-Known Member
    Canada
    2000 Corolla CE
    I know some of the wiring diagrams arent exactly right one wire was off when i did mine but i forget which one.
    i thought it was match the colors and you will be fine? thats what i did
    Canada
    2000 Corolla CE
    I forget which website mine came from it had the wiring colors and the pinout for the back of the stock stereo.The stereo pinout was 100% and what i used to figure out the wiring diagram was off.
