Pictures of my 2007 Camry (one of my T R D s)
Discussion in 'Pictures & Photography' started by TRD98TT, 2008年09月09日.
    93geoprizm Active Member
    you know i saw the exact same colored camry with those wheels and was like wow, now those are nice wheels. Came to found out they were TRD's. I was really impressed with those wheels but yea the car looks sick, a manual swap would be nice lol and of course an SC wont hurt
    Shifty SIdeways Noob
    Memphis,TN
    that supra is very very clean, hardly ever see them unmolested like that nowadays, you got a nice stable of cars
    darkgamer1912 Member
    CT USA
    i have a weird question what is up with ur filter is it in backwards or is is supposed to look like those cheap fan things from eBay
    On the Supra? LOL That doesn't look cheap at all. It even has it's own heat isolated box.
    pnyk33 300whp 4afte
    orlando,fla
    the supra and camry.
    :king:
    CT USA
    nah im not bashing it the supra is an amazing car and ur very lucky to have one i saw the heat box, it was just the filter looked weird not like a normal one it went from big to small towards the pipe where most are the other way around but w/e its still a sick looking car. Also is it a tt 2jz or is the single turbo
    TRD98TT I Love Twins!
    Stafford, VA
    1998 Twin Turbo Supra, 2007 Super Charged Limited Sequoia, and a 2007 TRD V6 Camry
    Thanks for checking out the thread and for the compliments.
    Don't worry, I know you are not bashing my car. The K&N filter is not in backwards and it is designed that way for two reasons. (1) The cold air box that it is in gets smaller from front to back and the filter follows those same lines. (2) There is fresh air channeled from the front of the vehicle to right in front of the filter and the design of the filter allows it to gather as much as possible. It is the factory sequential twin turbo setup and the engine code is 2JZ-GTE.
    -Ryan
    CT USA
    i c that makes sense i can see the inlet on the front. also thats so sick i would love to have a 2jz in anything it must a blast to drive. i would love to have one of those to rival my cuzs camero z28. would be an interesting race
    benzo36 Bowlaholic
    Lancaster, Ca
    I love the cars!
    Stafford, VA
    *UPDATE*
    I never understood why Toyota did not release an OEM dual headrest DVD entertainment system option for the Camry. So I decided that since I have made a TRD Camry (that Toyota again did not release as a package) it needed the rear headrest screens to make it just that much better.
    After doing a lot of research to see what could work, I came across an option that was offered for the 2008 Toyota FJ Cruiser (which really baffles me because there is not that much room in the rear seat of the FJ for an adult to sit comfortably and watch a movie). I compared the headrests from my Camry (dark charcoal leather) to the ones in the FJ and noticed that they were a 99% match. The only issue would be if the contol box for the rear headrest screens would actually communicate properly with the OEM Navigation Headunit. This is where I had to take a chance and order the 2008 Toyota FJ Cruiser Dual Headrest DVD Entertainment System (part # PT900-35070) just to see if it would be compatible (this was during the December timeframe).
    I have been on travel for work quite a bit since then but finally had some free time over the past weekend to begin the installation process into my 2007 Camry. Everything fit perfect and looks so nice now that it is inside the car but I did run into one small issue. The screens powered up like normal, played DVD/CDs like they are supposed to, the picture was really good, the wireless headphones worked awesome....but I could not get the audio through the car speakers using the AUX selection on the headunit. Also, the system does not come with any installation instructions...only operating instructions, so all of this was done by trusting my experience.
    After some trouble shooting, I figured out that since it was not made for the Camry, the rear headrest screens control box was missing one wire that sent the signal to the headunit letting it know that an AUX input was connected. Instead of re-wiring the entire system, I came across a quick and simple solution. I must have my IPOD cable connected to the AUX input connection that is located in the center console pocket. This allows me to select the AUX input button on the headunit. Then all I have to do is remove the IPOD cable from the AUX input connection when I want the rear headrest screens audio to play through the speakers of the car. Now, here is the real kicker. I have to make sure that that IPOD cable is connected back into the AUX input connection before I shut the car off. If I forget to do this, I have to pull my center console apart so that I can reset the rear headrest screes control box.
    Yeah, some of you might think that is a hassle but it actually is not that bad. The cool thing is that I am the only 2007 (GEN 6) Camry with an OEM Toyota Dual Headrest DVD Entertainment System :)
    -Ryan
    Rincon , Puerto Rico
    Ares Active Member
    Houston TX
    D Matrix Member
    Cleveland Ohio
    ::fap fap fap fap::
    Unique102 Well-Known Member
    Supra... :bow::bow::bow:
    That Camry is sweet as hell too...but I have a thing for Supras :D
    TRD!!!
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    That's awesome dude, clean Camry and even better Supra. Sometimes close to stock is just better.
    Stafford, VA
    Thanks all for the great comments. The only things that I don't like about a stock exterior supra are the front lip and the chrome wheels. So I have a Powerhouse Amuse front lip from Japan....
    and Volk GT-S Wheels....
    Sitting in the basement ready to be installed. I also have a GReddy 3 Row Front Mount Intercooler Kit....
    That needs to be installed. So I should have some updated pictures of the supra in the spring time :)
    -Ryan
    onetohate New Member
    yr camry > yr supra.. but im bias. LOL! thanks for sharing!
    Stafford, VA
    There are different things about both cars that I like/dislike so I consider both eqaul. By the way, here are some pictures from the Fort Hunt Park, VA end of season meet this past weekend....
    -Ryan
    Very clean. When are the Volk wheels going on?
    Stafford, VA
    Thanks. They are not going on until the spring time. I have not purchased tires for them yet and am still not sure which ones I am going to get. I love BF Goodrich and have always wanted the T/A KD but they are not making them anymore. I could get the T/A KDW but am not a fan of the tread pattern. Hopefully BF Goodrich will come out with some new styles next year for me to choose from.
    -Ryan
    Stafford, VA
    *Update*
    I hit a piece of a tire that came off of a tractor trailer truck with the front lip of my 2007 Camry. Instead of getting it painted, my best friend Simon and I decided to just wrap it with the 3M Di-Noc Carbon Fiber Vinyl.
    -Ryan
    I finally got around to installing a bunch of the parts that I had lying around in the basement for the Supra. Here is a list of everything that is done to her and some new pictures.
    Modifications
    Engine/Exhaust/Drivetrain:
    GReddy 3 Row Front Mount Intercooler Kit with Polished Hard Pipes
    Power House Racing Upper Radiator Polished Hard Pipe
    MVP Motorsports Cold Air Box Intake (Powder Coated Black) w/ K&N Filter
    TRD Generation 1 Exhaust
    Rod Millen Motorsports Downpipe
    Speed For Sale Electronic Oxygen Sensor Simulator
    GReddy Boost Cut Controller
    GReddy Manual Boost Controller
    TRD Single Disc Clutch
    TRD Stainless Steel Clutch Line
    TRD Limited Slip Differential
    TRD Oil Cap
    TRD Radiator Cap
    Titan Motorsports Carbon Fiber Spark Plug Cover
    MVP Motorsport Carbon Fiber Radiator Cooling Plate
    MVP Motorsport Carbon Fiber Hood Struts
    Dress Up Bolts Engine/Engine Bay Polished Titanium Bolt Kit
    Suspension/Brakes:
    Megan Racing Coilovers with adjustable 32-way rebound shocks, adjustable spring pre-load, and adjustable ride height by the threaded shock body
    TRD Strut Bar
    TRD Front/Rear Lower Anti-Sway Bars
    Speed For Sale Cross Drilled/Slotted Rotors
    TRD Stainless Steel Brake Lines
    Wheels/Tires:
    18” x 9” and 18” x 10” Volk Racing Titanium Gunmetal GT-S Wheels
    255/35 and 295/35 BF Goodrich G-Force T/A KDW NT Tires
    Volk Racing GT Center Caps
    Volk Racing Polished Lug Nuts
    Exterior:
    Amuse Front Lip (Wrapped in 3M Di-NOC Black Carbon Fiber Vinyl)
    20% Quantum Tint (All Windows)
    TRD HID Head Lamp Kit
    TRD Gas Cap
    Interior/Audio:
    TRD 10K RPM Tachometer
    Dual 60mm A-Pillar Gauge Pod
    TRD Boost Gauge
    TRD Oil Pressure Gauge
    GReddy Full Auto Turbo Timer (Custom Mounted in the Center Console)
    I have also been really busy with the birth and raising of my first child Kaleb Matthew who is also a TRD fanatic :D
    -Ryan
    JDMjody VVTLi > VTEC
    RIVERSIDE, CA
    04 Celica GTS
    lol, my son has the same shirt!!
    Edwin562 SWAG MASTER
    562 SoCal
    98 180sx
    clean set of cars...
    sick whips
    couple of suggestions, go lower on the supra, CF wrap your front lip on the supra or paint it red and tCF wrap the rear piece on the camry to make it all match. That supra is mint, how many miles does it have?
    Stafford, VA
    Very nice!!! My wife gave that to me as a gift when she told me she was pregnant.
    Thank you very much.
    Thanks for the suggestions and great minds think alike! I am planning to only do the black part of the rear lip (between the exhaust tips) and also the rear spoiler. I am trying to convince the wife to allow me to also do the two black plastic pillar pieces that are seperating the front and rear doors windows. Here is a picture to give you an idea.
    I have the CF vinyl at home to do all of the above and am also planning to do the front lip of the Supra but just dont have the time right now. I will eventually be painting the front lip to match the car but I need to get the JDM side skirts and rear splats so that I can get them all painted at the same time.
    I would like to go a little lower with the Supra but I am running a 295 out back which is pushing it for the stock body. Here is a picture of the rear to show you how close I already am and am not looking to rub (plus I do not want to cut/roll the rear fenders).
    Right now she has about 55,000 miles and original paint.
    -Ryan
    how about CF wrap the hood? me and mackman were discussing it the other day but didnt end up thinking too positively about it
    Stafford, VA
    I have thought about it but decided not to. I would just get a real CF hood if I was going to go that route.
    -Ryan
    Yes, that is a better idea, too much of the fake CF I think would not be good. I'm the aforementioned Mackman.
    Stafford, VA
    This is what happens when the wife dodges to miss a head on collision and hits the car to her right....
    Luckily my wife and our 6 month old son along with the other individuals involved are all ok. The vehicle that my wife missed having a head on collision with actually stopped and was charged with causing the accident. There is no frame damage, just exterior cosmetic stuff that can be fixed but who knows what the insurance will do.
    -Ryan
