Pics of my Luxury Toyota
    Kill you? After I paid you to make TRD replica parts? I don't think so, that would make investment unwise.
    i'm concerned that the muffler is the cheapest part on there....
    wait bmw parts are much cheaper than lexus parts.
    what the hell
    I was being sarcastic :rolleyes: im just suprised
    how does your muffler cost less than my celica muffler? :confused:
    There are cheap parts for the Lexus as well Press, I just don't like buying cheap stuff.
    And the muffler, I got it used locally (so no shipping). It is usually over $500.
    And that is by no means a complete list, it's just what I thought to mention quickly. Obviously there are cheaper things on my car, like........... um. well dang.
    Added: Oct 14, 2012 5:02 AM
    Ah, my high beam bulbs! They were only $70.
    Nothing I buy is bad though... The BC coilovers are cheaper than my other coilovers which are one of the best (not the lowest though)
    I'm definitely not going for cheap parts.
    OH yeah I'm not saying you go cheap either.... but the BC coils is a good comparison, I forget, were yours $8-900? And yours came with endlinks (another $200 for me)? Interesting... essentially the same thing, right?
    The BC's were $1190
    My other coilovers are $1600 new
    OK, so then mine at $1000 + $200 for the endlinks is exactly the same!
    omg thats one expensive list. maybe i should stay with a cheapo car
    I'm trying to poop right now but only letting out gas :(
    drink prune juice
    Added: Oct 14, 2012 3:31 PM
    drink prune juice
    All that money and your car looks like that.
    Yeah I've spent a bit more money on mods already than the car itself.... and a bunch of it was wasted of course (so it doesn't show) but oh well.
    I got a lot of work today, spent all day on the car (I did other things yesterday).
    Yesterday, while mowing the grass, I came up with an idea of plastic welding for the side skirts. I got a piece of the side skirts out of the trash and cut some rectangles out so that I could use them as backing to hold the halves together. I used my soldering iron to melt the seams together really well (both front and back). The result is surprisingly strong, these aren't breaking!
    Then the real work began. I set out to really dig into the car. I had to fix the front sway bar bushing mount (extract broken bolt, insert new bolt), lower all the coilovers, and install the front lip and rear bumper&lip.
    I started with the front.... I removed the sway bar. Luckily, the sway bar mounting bracket unbolts from the car, and there was enough bolt sticking out the other end that I could easily grind a slit and unscrew the stud. Then the new bolt went in perfectly!
    I also put on the front lip... fit like a glove and bolted on nicely.
    When I had first put in the fog HIDs, I didn't bother with the dust covers on the back because the HID wires were in the way. But when I swapped the fog bezels recently, I found plenty of dirt inside. So, I reused the caps by drilling a hole in the center for the wires, and the weatherproof seal on the wires is wedged between the projector and dust cap, sealing it up very nicely:
    With the front all finished and back together, I took the rear apart and installed the new OEM bumper & lip.
    When I was using the Vizage rear lip before, I had a problem with the exhaust not lining up properly, causing touch and melt the lip. Since I was using that lip again, I wanted to fix it properly this time. I unbolted the hanger so that it came down low enough for me to drill new holes and connect the new and old, giving me a wide hole to adjust the position of the exhaust as needed. I can't believe I did do this sooner lol (btw, the exhaust ended up all the way in the new holes:(
    Sorry, it was too dark to take pics (tomorrow :p) but I got everything done :) I ended up lowering the front 3/8" more and lowering the rear 1/8" more. Yeah it rubs and bangs more, but it looks cooler haha. I'll probably raise it up after the shows.
    I just need to finish the side skirts, then it is done and ready for a full detail!
    Oh, and I fired up my new projectors for the first time tonight....mmm nice
    Get 18's so we can scrape scrape scrape everywhere bro.
    That is the plan actually.... I'm sick of not being as low -looking as I want, even though I am extremely low.
    Yeah I'll be going down to 17s for the better stance myself. Looking for a set of 17x9
    WAIT....you didnt put chicken wire mesh under the plastic welds? its not gonna last gold
    What do you mean? That sounds like the stupidest thing I could have done haha. I forged the plastics together by melting, mixing, hardening. Should be as strong as the original plastic, right? But it's not like they are under any stress. I will be fiberglassing over the backs to stiffen them up so they don't crack once installed.
    OK ITS STUPID...I guess those 2 years of auto collision repair class were for nothing...
    you melt a chicken wire mesh on both pieces till it looks like it sank to have a strong bond...then melt the extra plastic on it...the chicken wire mesh is a critical part if you want it to hold....you can fiberglass on plastic but it does not have a strong bond, over time the resin will peel like removing tape from a bumper. if i were you i would go back and do them the right way....try and watch some video on youtube and you will know what im talking about. also buy a plastic welder gun, i got mine for $20 and i was able to combine my 8.5 and my 9.5 bumpers together...
    Oh it's not stupid I'm sure, just I never would have thought about it, since I'm welding plastic to plastic, and the plastic is strong enough by itself and adding a mesh or anything would just get in the way of a good bond.
    But I'm just using a soldering iron... I'm sure if I had a good plastic welder then I could do the mesh thing, but it was hard enough to get enough heat just to do what I did.
    And that's why I didn't just do fiberglass like I originally intended. Though I will use the dremel to scratch and roughen the backside all up to give it something to grip to.
    Added: Oct 15, 2012 4:58 AM
    and I saw a video about repairing plastic with a heated staple tool, so that's like the mesh thing. That's what got me thinking about the method I used.
    skip to 3:37
    Added: Oct 15, 2012 5:03 AM
    how is the mesh gonna get in the way? Its only on the back side of the part. you melt it down to the original pieces and then add more plastic on top to hide it
    I see, yeah that's very cool. But my soldering iron isn't hot enough to melt the plastic like that, it can only to a dot at a time obviously, and only touching the plastic directly.
    But I see how that is stronger, I didn't realize you mean push the metal down into the original plastic before adding more, I thought you just meant sandwich the mesh in there and then start melting.
    hmmm we'll see if it lasts
    I did the other side skirt today, and did it even better. Then I fiberglassed behind both.
    And I was able to snap some quick pics at work before it started raining.
    The front lip is on and the rear bumper and lip is on.
    The car is slammed even more, an extra 3/8" lower in the front and 1/8" lower in the back (and the front dampening is set to full stiff). I finally like how it sits, maybe I'll keep these rims after all lol :)
    The new fogs are in, the head lights are buffed, and of course the window visors are still on.
    Obviously the side skirts are not on, so you can see the minute difference the custom lip kit makes! Very clean and OEM-like :)
    I'm actually really happy with how this is turning out.
    it does look really good! now u gotta wash it and take some clean pics!
    Gold wash? Bitch please. :rolleyes:
    lol I did spray it off when I got home from work, after it rained. It seems to get a certain amount of dirty, then no more. But it is covered with sanded bondo dust. But I do have a car meet/show this weekend, a fill detail is in store before then (after finishing the skirts).
    Two more pics. I figured everyone else takes gas station pics, so why not lol:
    it looks like u spilled a ton of gas from the nozzle. someone drop a match :D j/k.
    Do ppl comment on ur car a lot in person?
