Help! Picchu get his coilovers installed correctly.
Discussion in 'Stop, Drop & Roll' started by Machupicchu, Aug 12, 2013.
    Sacramento
    01 Corolla S E110
    No it's black. That's weird!
    Ya I think I am going to pull them. Not sure what the best method is.
    Racist NPF
    Sacramento
    01 Corolla S E110
    Black=weird.
    I've pulled mine, the fronts are super easy because the metal is thinner. You can get a lot more clearance that way, I haven't had to change my camber at all (so better performance). I used a metal pole.
    They do adjust dummy you just pull the hub for positive camber and push for negative I had mine at -7 in rear
    Added: Aug 14, 2013 at 1:02 PM
    Say good bye to your fenders my friend
    JustA4Banger Member
    i think camber bolts might do the trick with a little fender pulling.
    also whats the specs on your wheels? 15x8 +15, what size tires are you running?
    Ok I was just wondering, because those look white lol
    Sacramento
    01 Corolla S E110
    I have them pushed in as far as they will go. Most I could at was -3.
    They are 15x8 et0 195/50 15
    I was running 15x7 + 33 offset 5mm spacer on 205/50/15 s
    That's what he said.
    Hey bro, you spelled your own name wrong in the thread title.
    I was like, "who's this Pichu" guy... then I :isee:
    Like a sir.
    Good job gold you scared him off
    Maybe he couldn't find the thread after he spelled his name wrong? We couuuuuuuuuld fix it for him lol.
    Done. :fyeah:
    Like a Mod Boss :fyeah:
    It takes an Admin to make a Mod Boss.
    lmao, this is very literally true
    Sacramento
    01 Corolla S E110
    In for the win, and he's back.
    Machupicchu likes this.
    And *someone* should photoshop a Pichu going apeshit (possible?) on MacchuPicchu for his avatar.
    Sacramento
    01 Corolla S E110
    Was going to photoshop pichu raping wobbuffet...searched pichu rule 34...stayed off the internet for a couple days.
