New Suspension Setup Question?
Discussion in 'Stop, Drop & Roll' started by |-Goku-|, 2006年10月10日.
    Maybe I should just stick with KYB and H&R's. DAMN the choices, its so hard to choose. lol
    I didn't want to post a new topic about this so..what about Camber Kits, will I need one since my car is going to be lowered?
    |-Goku-|
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    I recommend it if you do a drop lower than 1.5". Eibach is good... stay away from the crappy OBS ones on eBay. I had those and they sucked (poor quality metal).
    do I have to get an alignment done after I install A Camber kit? cause I need an alignment done now, should I just rotate my tires and wait on the alignment?
    |-Goku-|
    Silver Bullet New Member
    You will need an alignment after you install a camber kit. You should install the struts, springs and camber kit then get an alignment.
    Ro2la New Member
    Los Angeles, CA
    kyb gr2 and s-techs, good ride, no problems in 1 years and a nice drop (thats with a tom's lip kit). no alignment done after drop, camber kit isnt installed yet.
    So we are sure that Road Magnets springs from 93-97 will fit an 02? Will there be any modifications needed?
    |-Goku-|
    Rosedale, MD
    No modifications needed. They'll fit. I've exchanged suspension setups between my car and my friend's 97 numerous times.
    Hey Vamp, whats your opinion on Coilovers, are they the same, better or worse then just lowering springs???
    |-Goku-|
    Rosedale, MD
    Unless you're getting real coilovers and not coilover sleeves, they're not worth it. The ride will be harsh and you'll kill any strut you use with them real quick.
    What are considered "Real" Coil overs?
    |-Goku-|
    alby13 New Member
    yeah i had my tokicos for a long time. i had no problems with them. if you drive properly you can lessen the chance of messing the struts up.
