New Head Unit - EDIT: new problem!
Discussion in 'Interior' started by benterz222, Apr 17, 2007.
    benterz222 Guest
    Hello all..
    I'm new here so pleease be nice =]
    Right, well basically i'm getting a new head unit for my Corolla (1994) and was wondering whether or not you need any adaptors in order to fit an aftermarket head unit.
    The head unit i'm getting is - http://www.caraudiodirect.co.uk/son...7e3680b7bc9244f
    And i've found the following adaptors for Toyota corolla's... do i need them?
    http://www.caraudiodirect.co.uk/ind...5d24200c17f78b6
    Any help would be much appreciated...
    thanks in advance
    EDIT: next problem is basically.. how to i remove this facia to fit the new head unit...
    any ideas?
    cgreen38 Common sense, p
    Baton Rouge, LA
    Personally, I wouldn't go with Sony head units. Can you get Kenwood or Pioneer over there across the pond? :)
    benterz222 Guest
    well the only reason i was going with that head unit was because it was relatively good value and had all the features i needed.. can get Kenwood and Pioneer too..
    what are your opinions on the adpators? do i need them?
    you'll need one for the wiring harness, and you'll need a bracket/bezel. if you can find a kit that's specific to your gar, i'd opt for that.
    Baton Rouge, LA
    Sony stuff is OK, but you can get better for about the same price.
    fuzionrolla Guest
    yeah i say stay away from sony i had one replaced it by a kenwood and millions of differences... you need an adapter you should be able to find it for aboute 5 to 10 bucks i got mine from walmart
    To get to the radio do the following:
    1. Pull the black plastic knobs off of the climate control switches. There are 4 of them.
    2. Pull firmly on the plastic panel big plastic panel that surrounds the radio. You can put a screwdriver or other tool between the dash and the panel to pry it out, but be careful.
    3. Unsnap the connections of various wires attached to the panel. Then you should be able to remove the plastic panel completely.
    3. Unscrew the radio from its brackets. Voila!
    benterz222 Guest
    ninety four... thank you very much! much appreciated =]
