New 01 S
Discussion in '8th Gen' started by MattH, Oct 18, 2013.
    what are you controlling with the harness i sent you, what does it power up?
    It powers up a NPF
    MattH Country Boy Problems
    Central VA
    2001 Corolla s
    Tried it, fog lights won't work now. I checked the fuse. I tripped a DRL relay on my 99 and the headlights quit for awhile, but they came back on. Fogs aren't coming back on though. I'll have to get a relay from Toyota tomorrow.
    Did you put it all back the way it was?
    Central VA
    2001 Corolla s
    Yea, I put the relay in the same way it came out
    ON mine, there were 3 identical relays back there, so if one "broke" I could test it with one of the other ones to make sure it was broken.
    Central VA
    2001 Corolla s
    I tried that too, and they still won't turn on. I don't know what happened
    so the relay is fine.
    You sure the fuse is OK? You hear stuff clicking when you turn them on/off?
    Central VA
    2001 Corolla s
    I guess it's ok. Not sure why their not working. I'll check the fuse again.. The only one I checked was the 15a in the cab. I believe the only clicking was when the low beams and high beams were turned on.
    Yeah, the fuse on my car is inside. It was fine? Or did you have to replace it.
    Added: Nov 18, 2013 3:55 PM
    And so that I'm not confused, I believe you are trying to do two things at once? You're trying to do this relay thing, and also trying to get the OEM switch installed?
    Central VA
    2001 Corolla s
    The fuse was fine. I already have the oem switch. It's the ring on the stalk that turns up and down.
    I know, did you get that switch to work?
    Central VA
    2001 Corolla s
    It flicks on and off but the lights won't turn on. I have stock fogs and they worked before I tried this. I don't have the wire on the relay anymore. I didn't have a continuity tester to find an accessory wire so I hooked the other end of the wire up to the battery to test it.
    The fogs worked with the OEM switch? Sounds like there's something wrong with the wiring
    Central VA
    2001 Corolla s
    Yes they worked with the OEM switch. I have no clue how they worked before, but not now. There is power in the socket the relay plugs into AND there is power at the 15a fuse for the foglights. There is no power at the foglight housing plug.
    Well maybe the relay is bad after all... IDK. Maybe you hooked up the wrong pin to something? IDK. Other than double checking everything and trying another relay, IDK. IDK!
    IDK
    Central VA
    2001 Corolla s
    And there is power to the switch. I took the column apart to check. You think that relay is different then all the others?? When I check for juice on the switch they work and the relay clicks!?!?!?!? This is crazy. I'm thinking the switch is bad.. I dunno
    If the relay clicks, that means the switch and relay are working. Sounds like power is not getting from the relay to the fogs, or from the original source to the relay.
    Central VA
    2001 Corolla s
    Yea.. I'm gunna dig alittle deeper.
    That's what she said.
    Central VA
    2001 Corolla s
    The two 15a fuses in the engine bay block for "HL Upper or Lower" doesn't have power. I just jumped the relay from one prong to another and they come on with the parking lights. Eventually I'll get it looked at because my heat really only blows on high
    What does the heater have to do with the headlight fuses?
    Central VA
    2001 Corolla s
    I wouldn't think it has anything do with the headlight fuses. I'm just telling part of the story. I mentioned that I would eventually get it looked at because of the heater. Now instead of one thing not quite right, now theres two things not quite right.. Maybe I should get that looked at.. Lol
    Central VA
    2001 Corolla s
    I ordered Tokico struts 2 weeks ago and and they are on backorder. Supposedly they are having a hard time importing them. There is no ETA on them and this seems to be an on-going issue with Tokico. So the wait begins..
    Damn I was gonna possibly get those too, still deciding what route to take for suspension.
    tokicos are far superior that the stagg...i have tokicos + trd springs now on the body kit rolla, its suv status but im fine for now until i get new coilovers
    Central VA
    2001 Corolla s
    I got KYB's. I did the rear since those have been bad since I got the car. I had to do end links too because I had to cut them. They were way too seized up to get off with a wrench.. They were trashed anyway. Now I have a light tap/squeak in the rear. I know everything is tight.
    Teehee he said tight.
