Engine My ram air intake vs stock air box with K&N.....???
Discussion in 'Powertrain' started by ghoztrider, Apr 20, 2005.
    AE102 New Member
    lol you live close to there?
    hell i bet it does sound mean, thats the only True CAI for you northern fools :D even ram air intakes would be cold :p
    one issue, when it rains.
    ghoztrider New Member
    Suburb of Philadelphia, PA
    ya i was thinking that too, if it rains ur screwed
    SinGularity New Member
    speed holes lol
    statik New Member
    I do live in Alaska! North Pole Alaska. :D
    Hm. So if you put a hood scoop on and direct the air into the intake your screwed when it rains? What about a WRX, what happens to the water? (sorry I'm clueless)
    renfield90 New Member
    Tempe, AZ
    The WRX's hoodscoop isn't an intake. It's meant for cooling of the engine.
    Almost all hoodscoops are meant for that, and usually their location or the space in the engine bay makes it impractical to set that up as an intake. Plus, what would you do when you popped your hood? And even if you could get it to work, chances are the piping would be so crazy that you would negate some of the gains from ram air and you'd certainly be losing some power from a dead stop.
    statik New Member
    I need an education on hood scoops. :) I guess I am misinterpreting what I see with a WRX. It appears that the air filter is right under the hood scoop. Yes, I'm totally clueless. Is that not really an air filter, but an intercooler ontop of the T/B or intake manifold?
    I'm a bit off topic.. sorry.
    Back on topic; From the research I've done the 1zzfe stock engine needs a somewhat restricted air intake, such as stock. The CAI will boost your mid range power, but take away from your low range power. Adding a K&N air filter to a stock setup will increase gains in lower and middle power ranges.
    Vamp has removed his air resonator box, made it into a ram air intake, and kept a stock air box. That sounds like a good balance.
    It's in his DIY section under engine mods.
    http://vamp.darkravers.net/Domain.cfm
    Thats just the info that I've come across...
    gotarheels03 New Member
    yes the "thing" on top of the engine is the intercooler on the WRX. Top mount intercoolers arent as efficient as front-mounts though, so thats one of the 1st mods WRX owners do.
    back on topic, I dont think a SRI is worth it, with the underhood temps you're actually going to lose power, It probably flows better, but the air is definately hotter. Best options IMO are a CAI or Stock box w/ K&N drop in.
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    i was just gonna say that, but u beat me to it
    Bones New Member
    You can get insulating wrap for the intake tube. I've seen it in JC Shitney, but I'm sure you can also use exhaust wrap, or get it powder coated.
