My '93 Corolla From New Zealand
Discussion in '7th Gen' started by Sharpshooter, Apr 5, 2010.
    That's even worse.
    But still :fyeah:
    Sharpshooter Full Throttle
    Auckland, New Zealand
    Had some 8mm spacers on the rear wheels for about the last year. Only removed them a few days ago. Trust you to mention it now :p :D. I was using the standard length wheel studs and only have about 1.5 turns before the wheel nuts were tight wasn't a very nice thought, so I decided to remove them once and for all. Will no doubt install some larger spacers in future, next time with extended wheel nuts, but spacers need to be certified here so will get them done at the same time as the certification for the coilovers :cool:
    Here's my latest mod that I decided to install today - 266mm rear disc brakes! I converted from the old drum brakes to these nice shiny discs from a JDM AE101 Levin GT Apex (same discs/calipers used on the JDM AE101 Corolla GT sedan, FX-GT hatchback and BZ Touring wagon models). The discs and pads are brand new so I had a bit of fun earlier bedding them in earlier :). Took me half the day to install them as I had to run the new handbrake cables and painstakingly remove the long bolt that goes through the lateral arms but I got there in the end. Here's some photos of the finished job:
    MACK likes this.
    Nice!!!
    What about bolt-on spacers? Like 25mm.
    Time for a BBK!
    Nice conversion! I'll have to do some research on parts required to fit this to an 8th gen!
    those are bolt on.
    If that is the case, please keep an eye out!
    You should just have corollagt do a write up. I dont think its the rocket science cbass makes it out to be.
    MACK likes this.
    you have to import them...no US corolla had them, the AE92 is the closest thing to get but you need to get the stabalizers arms welded on the end of the ae92 ones.
    Corolla GT has AE92 rear discs, it's a different fit. cBass is trying to do the conversion with more readily available parts.
    im making it rocket science because im trying to make them a direct bolt on because most corolla owners wont want to weld or fabricate stuff....then once i do ill make a write up.
    Keep it up bro.
    Oh god, not a cbass write up.
    hey scott just throwing it out but how much would it be to get those rear hubs with calipers sent to the US? id imagine alot
    I think cbass should do a video. :troll:
    x3
    Added: Mar 31, 2013 at 2:31 AM
    A bullying video.
    ohh man not that dumb video...have you seen it james?
    I saw it on your youtube thing maybe but I didn't click on it.
    x8 <---- my favorite number
    Yeah James, you should watch every one of his videos. Not only will it make him rich, but you'll learn lots of valuable TRDforum history!
