My '93 Corolla From New Zealand
Discussion in '7th Gen' started by Sharpshooter, Apr 5, 2010.
    *throws hands up in the air like I don't care*
    Nice header Scott!
    Sharpshooter Full Throttle
    Auckland, New Zealand
    Thanks!! :D
    I decided to put my digital calipers up against the standard mid-pipe to see how bad the restriction really is where it goes over the subframe. At the pipe's widest point before the restriction starts it measures in at approximately 53.57mm (2.10"), and at the pipe's most restrictive point (where it goes over the subframe) it shrinks right down to approximately 28.10mm (1.10"). After the restriction the pipe goes back to it's original size of 53.57mm (2.10") but the disruption to the flow of the exhaust gasses would be huge.
    The FGK header set retains it's original piping size the whole way along, so it makes me wonder why Toyota decided to hammer the piping down so far when there's so much room between the underbody of the car and the subframe. Admittedly, there are usually heatshields covering the mid-pipe, but even so there's still plenty of room under there.
    It's hard to tell how bad the restriction/pancake effect really is from the photos but in real-life it looks terrible. It's easy to see why I noticed a gain in power almost instantly after installing the FGK set:
    wow dude that is hilarious...damn you toyota!
    Can't wait to put mine on too!
    So it was actually designed like that or did that happen over time from getting pinched?
    Yep it was actually designed like that. The original heatshields had no signs of any dents or damage to them so it definitely was done in the factory.
    Here's some new photos that I took today:
    Gold and MACK like this.
    Awesome as always
    I would say you need spacers in the rear :)
    x2
    Funny, I say the same thing lol.
    x2
    double post fail...i thought you got a new mouse
    Oops. No I never did get a new mouse, since this one wasn't double-posting anymore.
    I forgot. Are his tails led?
    Scotts? no....
    Then he needs some!
    Just put some LEDs in my turn signals in the back. Can't wait to get pulled over.
    Have fun with that.
    Why would you get pulled over? lol.
    Unfortunately, there are no OEM LED tails available for the 7th gen.
    Make some!
    And because the law is you have to have amber or orange turn signals.
    And mine are insanely white.
    That means hes a racist.
    :kidding:
    It seemed quite fitting :D
    That's what she said.
  31. Offline
    No more halfshafting!
