My 8th gen Rolla
    jdmgen8 Well-Known Member
    Spartanburg, SC
    2002 Toyota Corolla CE
    Where did you get that spoiler mack?
    Added: Feb 16, 2013 at 7:09 PM
    Nice, i eventually want 205/50's but got this set of 195/60's for free and pretty much new.
    Milky Enlarged Member
    yeah, the 205 is decent. i still spin a fair bit in 1st and 2nd. this is also on nitto neo gens, which have pretty good dry traction. good in the rain as long as you keep your foot out of it. i got the whole set mounted for 360ish..
    I got my spoiler from a member on TRD about a year ago. cBass is making replicas if you're interested.
    Yeah you should definitely get one, and get rid of those awful altezzas!
    Well the ones I linked are only $45, and they probably match better than yours without all that extra work. I don't think these are on Ebay often, which is why you had to get the clear ones?
    Nah those premade ones are all over the place, not sure about the matching. It's probably pretty good but I enjoyed making them.
    Spartanburg, SC
    Yeah it looks good how did you mount it?
    Added: Feb 18, 2013 6:32 PM
    Yeah havent had em on long, probably gonna get the ones he linked on ebay. I didnt see em when i was looking for tail lights.
    Just go back to OEM, lol.
    Spartanburg, SC
    Ive been thinkin bout doin that for a while now, just havent gotten around to doin it.
    Spartanburg, SC
    Nice, mine doesnt have enough power to spin unless i just dump the clutch lol
    A c60 and LSD changes everything. 4.53 final drive for the win.
    Spartanburg, SC
    what car does a c60 come out of?
    00-05 celica gts, 03-08 corolla and matrix xrs's. And any lotus elise or exige.
    Spartanburg, SC
    Oh ok so those will bolt right up can you use our cv axles or do you have to swap axles also?
    OEM 98-00 trunk lights with those clear-signal ebay outer looks very nice IMO, definitely the best way to go.
    Spartanburg, SC
    I havent seen the clear ones ill have to check em out.
    Bolts right on to the engine and into the car. The front and rear mounts bolt on, the passenger side trans mount needs some minor mods, but nothing major. As for axles, if your engine is tapped for the carrier bearing, use a 94-99 celica gts passenger side axle. Drives side is a 00-05 that needs to be shortened by 7/8ths of an inch. Take it to a local axle shop and they should be able to do this for a small charge or contact moser and send in a shortened axle shaft and they will make you a new shaft in the right length.
    We got it gold, no need to reiterate.
    It's the ones that you've been talking about. Facepalm
    Spartanburg, SC
    Thought he meant clear with no red :rolleyes:
    That's because gold is a retard.
    :youdontsay:
    Glorious!
    Spartanburg, SC
    How many miles?
    Spartanburg, SC
    160k its never been changed so i figured itd happen sooner or later, its not really bad but will need to be changed. Ill probably do it with tax money.
    Thats surprising.
