Engine motor swap???
Discussion in 'Powertrain' started by bxman89, 2012年04月20日.
    I need help with my 1JZ swap. Help?
    Agreed :sir:
    Hummer likes this.
    Rollas98 Member
    Toyota Corolla 1998 LE
    2jz ??
    Added: May 13, 2013 at 5:30 PM
    Can that engine fit our engine bay ? or is the 3.0L mark the limit ?
    3.0 and the 2gr are similar in sizes. I highly doubt anyone will every attempt a v6 swap though
    2JZ definitely won't fit.
    Rollas98 Member
    that is sweet :D
    Added: May 14, 2013 at 6:09 PM
    I was afraid of this one. The Celica in that video looks like it's struggling to move with that 2jz.
    im pretty sure he is trying to do a burnout
    Rollas98 Member
    That engine got me there :awyeah:
    Rollas98 Member
    Is that engine a legal swap? Because I know the Toyota Blade has one.
    Yes, it came in the Camry in 07+ so you can BAR it if it has all the emissions controls intact post swap.
    Rollas98 Member
    Holy **** man, 0_O that is ultimate destruction. Imagine that in our 2400lbs car. I think the cost would be similar to an MR2 Spyder swap.
    Hell yes, that would be nice. Although I bet a 1ZZ S/C could take a stock 2GR-FE swap. Dual vvt-i is gangster though.
    You mean putting that engine in an MR-S would be the same price as putting it in a Corolla, right?
    a 2gr can be legal. But would require so much to do so.
    Bro. An 8th gen corolla is not that light.
    :please:
    Rollas98 Member
    I though they weight 2414. o_O
    Go look at the sticker inside the drivers door area.
    Rollas98 Member
    the sticker has me confused is it 2500 ?
    Added: May 19, 2013 at 7:29 PM
    I would think so, since they both have the izzfe motor. We can always go cheap at carparts, cragslist, or at the eBay sites.
    The 2rg- is in the 260-300 stock range
    Can the 1zzfe s/c lead the way by killing the 2gr-fe with just 250hp? along with better suspension mods and transmission?
    I through the 2zzge would be able do that with over 200 na
    I thought it was lighter than that.
    The sticker on the door jam is Not the weight of the car. That is the Safest Maximum recommended weight for the car. The curb weight of a 8th gen Corolla Starts at about 2400 lbs and goes up from there with options like sunroof, power windows, power door locks. At most, A fully loaded 8th gen Corolla is going to weigh about 2500lbs
    Added: May 19, 2013 at 10:33 PM
    The only way a 1zz or 2zz will beat a 2gr is to be boosted with a TURBO and hitting around 320whp. The only way you can get those numbers with a Supercharger by modifying the TRD supercharger with a bigger rotor or having a custom bigger supercharger. The TRD Supercharger is too small to go over ~220 hp reliably.
    It's not just about hp. The 2gr has almost as much Torque as horsepower. A N/A 2zz can reach 200+whp but will have about 140tq.
    Yeah the older Corollas were in the lower 2000s.
    Rollas98 Member
    Is the trd supercharge 1zzfe able have a head start before the 2gr kills it ? The 2gr is freaken dangerous. :eek: There's no 4 banger that can surprise or rape that motor without a reliable f/I installment. The rotrex c30-84 supercharger can hit 300 with upgraded internals. How much hp can the stock rod bears take on the 1zzfe ?
    [IMG][IMG]
    [IMG][IMG]
    Rod bears are hungry.
    Honestly... If you got the pockets to be building a 300hp Rotex supercharger setup. Upgrading the Rods shouldn't even need to be asked.
    Man you guys love these corollas.
