Interior air filter replacement
Discussion in 'Interior' started by stewardcboy, Sep 4, 2003.
    SoCal_CJ Guest
    Ok I received the one from Filters-now in my previous post , works cool, $12.99, seems to be a better as in traps more crap than stock as well as cheaper than stock. fits easy too, I took some charcoal prefilter material and double sided taped it to the back side as to let the filters folds do their work on the front, or intake side and the charcoal stuff on the exhaust side of the filter, grabs some gasses and smells. Tape it good, cause if it falls, it falls into the fan, see the Filters-now filter has a frame, so I taped it to the frame, used double sided foam tape and they re-enforced it with some packing tape on the edges.....I think problem solved,,,
    for those interested... you can go here and find info on the charcoal filters rating on gasses and smells...
    http://www.filtersnow.com/fnobtech.php#content
    Some folks may not care about the charcoal material, less allergy sensitive than I and the larger smells will also be blocked by the Filters now filter too so in that case, no mods, just slide it in, easy as stock, one screw on the outer side of the glove box, squeeze the lid a little and pop it off, pop open the filter cover, slide old filter out, slide new one in, 5 mins.
    this solution is Cheaper than stock, better than stock and just as easy
    03ToyMan New Member
    c0d3r Guest
    Has anyone else tried the Filters-now Filter?
    Or what other filter have you used?
    SoCal_CJ Guest
    seems to work fine, if I get behind a bus I hit the recurculate button and breath clean air, the charcoal pre filter helps out the smells and the regulat filers gets the rest...
