Intake mods
Discussion in 'Powertrain' started by Machupicchu, Mar 29, 2012.
    where did you buy the kit or the pistons/rings? i was going to get one off ebay for $350 at a time....i was thinking of fixing the 1zz up and keep it as another spare
    Sacramento
    01 Corolla S E110
    Sacramento
    01 Corolla S E110
    So my idle still hasn't gone down, when warm it idles around 1500rpm, and i still have very very rough about to die idle in the morning. I figured i was't getting all the way closed on my throttle body so i tried to adjust it but it's already set as closed as it will go. Iv also tried checking for a vacuum leak with carb cleaner quickly.
    Any ideas?
    Added: May 9, 2012 1:29 AM
    Also I'm still getting a power loss in between 80% and 100% throttle.
    Do you have cruise control? The throttle cable is also connected to that, it could be too tight up there somewhere, causing the butterfly to stay open. Highly doubt it but you never know.
    Bdub215 likes this.
    Bdub215 3VZ; 2JZ
    Philadelphia Pa
    93 ES300, 92 SC300
    Vaccum leak is my guess.
    use a cuban cigar
    HummerH2O likes this.
    Sacramento
    01 Corolla S E110
    thats what I'm thinking, i actually messed with my throttle cable up in the cruise control box thing. But i completely loosened my throttle cable at idle so i would be sure it wasn't pulling, and then tried to adjust the idle screw to close more but it would't close any further. I reset my battery overnight and when i drove to work this morning it had 0 power and was lunging like crazy. :mad: Might be in part from the computer being reset.
    Added: May 10, 2012 1:45 AM
    Whats a smoke test? Hold something smoking around areas that are prone to vacuum leaks?
    Hey looks like I am not totally useless after all lol. That was my first guess was cruise control. But you could just go to a shop, tell them you think you have a vacuum leak and see if they can do a test for you.
    Sacramento
    01 Corolla S E110
    ya I'm thinking about going to a shop, specially because i still have a CEL and now this. I'll just feel like less of a man LOL
    call in a good friend that knows about cars, taking it to a "mechanic" would be the last thing on earth i would do...
    Sacramento
    01 Corolla S E110
    Thats how feel about it. Im going to try that smoke test.
    what code do you have?
    Well yeah I don't think anyone would want to go to a "mechanic", I'd prefer to go to a mechanic.
    i wanna hear this new intake manifold already i wonder if it will make the trd exhaust deeper !
    Sacramento
    01 Corolla S E110
    I'm going to get a vid after this, it will just be a sound clip though.
    Power started picking up and evening out again, i think that was mostly my computer, but it still idles like shit in the morning and high when it warms up.
    Use a mango, hahaha..
    Added: May 10, 2012 11:05 PM
    LOL @ SIG.
    Why does he have to talk like such a douche? I dont even know how to describe it...
    haha, that video was great!
    and now I see the sig is a gif... it wasn't playing at work lol.
    Sacramento
    01 Corolla S E110
    Heres a sound clip, keep in mind this was recorded from my laptop in the passenger seat sooo, just wear some headphones or something.
    Added: May 11, 2012 12:21 AM
    it ends at like 1:20
    Sacramento
    01 Corolla S E110
    Sometimes when i start it runs ok. And then i can turn it off and go into the store for a minute and start it again and it runs like shit.
    Bdub215 3VZ; 2JZ
    Philadelphia Pa
    93 ES300, 92 SC300
    That sounds like i'm listening to youtube through a seashell. I cant tell what that is at all.
    Sacramento
    01 Corolla S E110
    ya i don't have a video camera, or phone that takes video. lol
    Sacramento
    01 Corolla S E110
    so i put the thermostat back in and now its overheating again. No flow through the radiator. Iv gone through 3 t-stats. The 2 i have left i have tested in boiling water and they open fine. i don't know whats going on. Pretty frustrating. Thanks for always helping me out guys.
    Hmm lemme think about this one. Overheating cars is things I've usually been good at.
    Sacramento
    01 Corolla S E110
    Also did some thinking, ok so if the entire cooling system is bone dry, and then i start filling it from the radiator, wouldn't it just fill the radiator and stop at the thermostat before the entire engine block and pump? How would the thermostat even activate if its not submerged in liquid?
    Added: May 28, 2012 7:42 AM
    I didn't fill the engine block:rolleyes:, I'm amazed at how oblivious I am sometimes. Should be running tomorrow.
    So you solved the problem?
    Sacramento
    01 Corolla S E110
    We'll see later today it was too late and i did't want to go back out and work on it.
    ToyLowRolla Well-Known Member
    Did you burp the system completely?
    I had an air bubble in my car and my gauge kept reading hot.
    It still does that sometimes but it goes away after i blast the heater for a few seconds.
    ^^Yeah we told him how to do that, he didn't do it before but hopefully now :)
