Intake mods
Discussion in 'Powertrain' started by Machupicchu, Mar 29, 2012.
    Sacramento
    01 Corolla S E110
    Blue Corolla, white hood for now.
    Sacramento
    01 Corolla S E110
    Pics!
    Uploaded with ImageShack.us
    And heres my dilemma, i heard the injen CAI for the 9th gen corolla work with 8th gen if you relocate the battery. So my brain kinda went half retarded and made me think all 9th gen CAIs work with the 8th gen corolla so i bought this TRD intake, well its not gonna fit without some holes being cut, so thats where I'm at.
    So the black connector hose is your problem? Go to AutoZone and get a Spectre multi-diameter coupling. Cut-to-length and multiple sizes.
    Sacramento
    01 Corolla S E110
    I got it all installed, i just haven't updated because I've been dealing with an overheating issue now. :(
    Did you do a coolant flush or anything? Check your thermostat too.
    Sacramento
    01 Corolla S E110
    fuuuuuuuuuuuck! New thermostat, filled it up turned it on, no flow what so ever. fans came on, no bubbles, upper rad hose hot, lower cold, overheating. Still haven't flushed it though.
    The coolant comes out of the top rad hose from the block right? So it doesn't matter if my upper rad hose is higher than the radiator a little?
    Did you bleed the cooling system ?
    I dont know if it matters but did you reset the ecu by unplugging the battery?
    Sacramento
    01 Corolla S E110
    Ya it was reset. unplugged it when i put new t-stat in. Could the water pump be bad? or the relay? i just changed the pump like 6k miles ago.
    Sacramento
    01 Corolla S E110
    gonna flush everything today, also check the water pump.
    Check it all, fuses, relays, water pump what ever you can.
    You sure theres no clog in the line? Or anything at all that would obstruct flow?
    Sacramento
    01 Corolla S E110
    Success!:D But i kinda cheated...
    Added: May 3, 2012 10:41 PM
    Its taking awhile for the computer to figure it out. At first I pulled out onto the street and punched it and was like:(, bogging, super rough acceleration, but after about 10 minutes It was getting better.
    So what, did you do anything? Or just give it time?
    Ohhhh, so the computer was just trying to learn the new intake system?
    Sacramento
    01 Corolla S E110
    Flushed the block and radiator with hot water, and took out the t-stat. It burped and then worked great. Im going to leave it out for now, but ill need to put it back in when it gets cold again. Im not sure if that was the blockage though, because there was no flow whatsoever after i put a brand new t-stat in.
    Added: May 3, 2012 11:26 PM
    As for the computer idk. Im gonna give it a few days and see what happens.
    Bdub215 3VZ; 2JZ
    Philadelphia Pa
    93 ES300, 92 SC300
    Me thinks you have a defective thermostat.
    Sacramento
    01 Corolla S E110
    Ya that would be quite the coincidence. Im going to return the new one, which i guess is defective.
    you got to remember it was not going to be a direct drop in...but it will work
    you have to move both fuse boxes, i should have told you that before, should be easy...i did that when i was running a 9th gen SRI
    use the hole where the stock intake resonator is, you are going to need to cut the hole bigger, make sure you spray some paint so it does not rust the cut areas...ive seen this method in real life work, some guy showed me his set up at the meet, ill take a picture next time
    Sacramento
    01 Corolla S E110
    Sounds like exactly what i did haha. ill take some more pics on sunday when i have the number off again. hopefully the computer stops being retarded by then and i can take a video
    You bled the air out of everything though right? But yeah sounds like a thermostat being defective. Don't run without one for too long if the weather cools down. Won't be able to get the engine up to a good temperature.
    Sacramento
    01 Corolla S E110
    Drove to work this morning and it was better, still lacking power, it idles super rough on a cold start, I had to keep the idle up a little. And i need to put that t-stat back in, it did't get anywhere near operating temp.
    Sacramento
    01 Corolla S E110
    Definitely starting to feel the power improvement, less low end but the VVT-I kicks in HARD!
    Still need to but t-stat in and adjust the idle screw, it's getting too much air at idle and cold starts.
    looooooooool im surprised my shit still works
    Sacramento
    01 Corolla S E110
    220k, oil burner, abused, salvaged 3x, old
    i just step on the gas and the rpm just jumps
    vuuuuuVVVVVUUUUUUUUUUAAAAAAAAAAAVVVVVVVVVVVVVUUUUUUUUUUUUUUUUUAAAAAAAA
    lol im stupid, anyways any progress pics of the setup
    Sacramento
    01 Corolla S E110
    Hahah, ya mine was burning a quart a week and i wasn't having it so i rebuilt it with the revised pistons and rings, wish i would built it with stronger parts but... i don't think i want to boost it, i wanna keep my gas milage. Im holding off on the big build until i get my 510. Anyway, gonna take more pics when i put my thermostat back in and hopefully take a vid.
    Sacramento
    01 Corolla S E110
    This thing is soo loud. It's like fart can ebbay muffler loud. Ha
    Just from the intake?
    Sacramento
    01 Corolla S E110
    Ya, like echoing down the street loud.
