Intake mods
Discussion in 'Powertrain' started by Machupicchu, Mar 29, 2012.
    thanks man
    Sacramento
    01 Corolla S E110
    Just red your other post, i remember NOT replacing the gasket when i replaced the IACV (WTF is wrong with me) soooo i guess i need to check it.
    just giving credit where it is due :D haha
    duuuuude you wanna check that out asap. also be very careful with it, its very fragile.
    Bdub215 3VZ; 2JZ
    Philadelphia Pa
    93 ES300, 92 SC300
    2012 and using a Kmart camera.... :/ disappointed.
    lol it was with my phone man, i can get a better vid. Just wanted to show that for people who didnt think it could be done.
    Speaking of 2012, when did avalons become cool? Lol
    Jk
  7. Online
    I think the 2012 Avalon is kinda cool looking. kinda
    Bdub215 likes this.
    Bdub215 3VZ; 2JZ
    Philadelphia Pa
    93 ES300, 92 SC300
    i can dig it.
  9. Online
    Yeah it has those cool light tubes in the tail lights and actual HID projectors. I didn't expect those on a Toyota! Too bad the new Camry didn't look more like the Avalon.
    Bdub215 3VZ; 2JZ
    Philadelphia Pa
    93 ES300, 92 SC300
    New camry sucks IMO anyway. All that good power wasted through a automatic. where's the manual option? Its about time i wrote toyota a nice letter again.
    Because the first one was so effective...? What was it about.
    Sacramento
    01 Corolla S E110
    K i ran a can of carb cleaner through the cat and replaced the downstream o2 and the light came back on.
    Added: Sep 20, 2012 12:57 AM
    Except im not a ginger^
    Man are you sure your ECU is not playing games with you? ive heard before that this can happen
    That's my next move if these hoses don't fix my problem is to swap ECUs. Reading up on the deal the EPA made with Toyota shows that sometimes the ECU is the cause of the code I have.
    /thread jack
    It just randomly started idling at 1,500rpms again
    Sacramento
    01 Corolla S E110
    Ya i thats what i thought before, i had the ECU swapped from the guidelines and diagrams over on the swap thread on TN, it worked but none of the self tests were running, so it would be impossible to smog, and that goes for anyone who used those diagrams. So i had to put it back.
    I need to beg Irvin to post up some simplified version of the FULL swap so all of the tests run. Either that or find some time to figure out the wiring manuals he sent me.
    your not alone :rolleyes:
    Sacramento
    01 Corolla S E110
    Well maybe we can plug away at it together
    Just said fuck it and bought a new idle control valve=problem solved
    lmao!
    Added: Sep 21, 2012 4:43 AM
    Is that a Daewoo? LOLOLOLOLOLOLOL
    Sacramento
    01 Corolla S E110
    nice, no codes?
  22. Online
    Looks like an old Mazda
    Sacramento
    01 Corolla S E110
    I forgot to mention, i had my car smogged a couple weeks back, knowing i was going to fail but i wanted to see the emissions. I passed emissions, so would't this mean that my cat is fine and something else is causing the 420 code?
    Heres my emission results.
    --------------------%CO2-------%O2------____HC (PPM)____--------_____CO (%)_____
    Test-----RPM-----MEAS-----MEAS-----MAX-----AVE-----MEAS-----MAX-----AVE-----MEAS-----Results
    Idle-------759--------14.6--------0.0-------100-------17----------55------1.00-----0.00-------0.09-----PASS
    2500----2500--------14.6--------0.0-------130-------12----------35------1.00------0.10-------0.27----PASS
    Meh
    I actually dont know.lol
    yes, no codes
    Added: Sep 21, 2012 5:40 PM
    exhaust leak? i say that because a leak can make you run cleaner and still throw a code. also checl for vacuum leaks in the intake side
  25. Online
    If your cat was bad, the HC number would be through the roof!
    Sacramento
    01 Corolla S E110
    Right, thats what i figured, soooo i mean, MAF and both 02 sensors are new, manifold gaskets are new, down pipe donut gasket new, throttle body gasket new, IACV new, new injector seals, valve cover gasket, P0171 LEAN CODE IS GONE.
    Where should i start? Exhaust leak?
    i would say ECU,, i remember reading something like that, they changed hella shit and the computer ended up being faulty causing the code...try and borrow one, see if it does the same thing
    Try the anti-fouler mod on your downstream o2 sensor
    Sacramento
    01 Corolla S E110
    Wouldn't a faulty computer show more signs of being faulty though? I mean my readings look pretty normal right? I wish i had a spare ECU laying around or could borrow one from someone ;);)
    Can i get the anti fouler at an auto parts store?
    Added: Sep 22, 2012 1:23 AM
    K im going to try the anti-fouler mod tomorrow, if that doesn't work I'm applying for the CAP program and taking it to a fucking mechanic. Maybe ill find time to work on a FULL ecu swap and see if that helps as well.
    I think you have to ask for the spark plug extender, they have the same thread size....and i have an auto
    Added: Sep 22, 2012 1:27 AM
