ignition switch light
Discussion in 'Interior' started by GSE21tuner, Aug 28, 2007.
    Is it that glowing ring around the ignition? I would think you need to remove the shell around the steering wheel and column.
    does anyone know a step by step procedure to replace the ignition switch light?
    DOT. Noypi ako!
    SD_S New Member
    SF, CA
    There are two Phillips screw on the steering column, turn your steering wheel left to right to access the screws and one small Phillips screw on the bottom. After that pull the bottom apart down and I think you will have access to the illuminating ignition switch bulb. But I forgot what bulb size it is.
    SD_S New Member
    SF, CA
    Hey vibe I too have an S but I dont have illuminating ignition switch. I know only the LE have that feature. How did you get a hold of yours?
