Hyper White Bulbs
Discussion in 'Exterior' started by meccaxpnoy, Jan 11, 2003.
    akira2003 Guest
    the headlights are not straight up blue,but very bright with a blue tint to them, plus since my car is dark blue and i have blue neon inside it all kinda goes together pretty good!
    Crazyness Guest
    For some reason My fog lights bulb keep blowing up.. I have changed them twice. The first pair i bought were Made by Mtech and the second ones were from Piaa... I wanna get the yellow ones now.. the ones that look like the IS300
    Syndicate Guest
    ...were the H3 bulbs you purcased 55W? If so, did you touch the bulbs w/your hands during installation?
    Raiyn Guest
    Okay installed the low beam sylvania sliver stars, love them..thinking of picking up the ones for the highbeams as well....
    QUESTION: since sylvania doesn't have any for the foglights which company can get me the same super white effect for the fog lights at as resonable a price as the sliverstars were :?:
    akira2003 Guest
    i bought "Lite Glow" blue bulbs, they have a great blue color to them , i actually bought them at Target for like 13.oo.
    yeye Guest
    Damn whered u buy em from for $16?
    meccaxpnoy Guest
    does anyone recommend Eurolite Hyper Whites?!... one of mah boys mite get some for me...
    SF_Rolla Guest
    just put my silverstars in last night and they look tight. Im gonna get the fogs lights changed next week too... for the low beams get the 9006-ST and for the fogs get the H3 or H4 i dont remember.... I HIGHLY RECOMMEND SILVERSTARS!!! 8)
    Syndicate Guest
    ...the foglights use a 55W H3 bulb, actually I just installed my Osram All Season bulbs. I can't wait to see what they look like tonight. It was a pain to install them thanks to the snow and the ice. Anyways, why would you want hyperwhite foglights? As most hyperwhite bulbs produce their effect by blocking out the yellow light that is produced. In a foglight you want this yellow/white light so that the foglights actually aid in visibilty when they are required (fog, rain, and snow).
    RollaS New Member
    i wouldn't mine only lasted like a month. silverstars is the way to go.
    MDRolla Guest
    Silver starts runs $25 each + 5% tax.. but they sold out of 9006s everywhere I checked.. not many places carry them as well..
    Do you guys know when does the rebate expire? It doesn't say on the rebate form.
    Peace
    Syndicate Guest
    ...the rebate expires 06/30/03
    xflywonthanhx Guest
    what bulb size are the fog lights??
    SSJ_Rolla Guest
    H3
    Syndicate Guest
    ...I installed my Silverstar 9005s last night and they are much brighter than the OEM Sylvanias, I would have to say I'm quite pleased w/them. The installl was kind of funky on the drivers side light b/c you have to move the air box snorkel if you don't have a CAI. The manual says to unscrew it using a philips head screwdriver. However, if your car is like mine it may be a flat clip, you can carefully pry this up w/a flathead screwdriver and then move the snorkel to the left. It's still a tight fit, if you can remove your battery tie down that may help as well.
    SF_Rolla Guest
    Fog Lights....
    I know alot of people already changed their fog lights but i was just wonderin if it was hard tryin to change them??? Im not sure if im correct but can u see the nut that holds the fogs in when pop the hood and look below? Bcoz i could see some sort of bolt down there thats threaded onto a long thread and i can sory reach it. Or would it be much easier to go underneath instead???
    Syndicate Guest
    ...you have to go under the front of the car to change the fog light bulbs. Just stick your head under there and you'll see the nut, just don't do this in the snow and ice like I did...the entire assembly just slidea out after the nut is off.
    minja714 Guest
    do any of you konw if H4s will fit in our H3 foglights instead? I ask because Silverstars dont make H3 I think... do they?
    Syndicate Guest
    ...no they will not fit, H3 and H4 bulbs are very different.
    akira2003 Guest
    it is really easy to change the foglight bulbs. if you crawl under the front of your car. there will be on bolt holdong the whole foglamp assembly in. unscrew that, and twist off the wireharness from the back of the foglamp housing.
    then the whole thing will slide out towards the front of the bumper. remove the spring clip switch bulbs (((((((((((((((((((((( dont touch the bulb)))))))))))))))), put the spring clip back in, push assembly back onto the front bumper
    screw in the wire harness from behind and tighten bolt. finished!
    RohllaNewbie Guest
    would the bulbs have a chance of being damaged if we touched them wearing gloves? :idea:
