Wanted Hotchkis Swaybars
Discussion in 'Wanted: Car Parts' started by 1nicetrd, May 20, 2012.
    wait, are we talking about end links or sway bars haha :confused:
    I've got adjustable end links on mine, you just shorten the to compensate for the amount lowered!
    I need to chime in.
    Swaybar modifications (going to a softer/stiffer swaybar, adding or removing a swaybar, or changing endlink lengths/angles) will change the roll stiffness of the axle where the modification was made.
    This always makes a difference in how the car handles.
    So how would I know what enough compensation is...?
    ^^^ On mine, since it's so slammed, I just made the end links as short as possible. I think it's guess and check though, just trying to get the sway bar in it's original orientation. But any adjustment closer to stock is better than no adjustment.
    You should "chime in" more often James!
    So if i can make a set of these i will be good for now[IMG]
    Fuck your sig makes this forum slow.
    No it dosent.
    Not on the phone but on my slow computer yes lol
    The whole forum is slow, or just loading the sig? I find most times it's just stuck on the first frame lol.
    You think you can make a set of those? Well good luck then, because that's what the professionally made adjustable ones are gonna look like.
    Well those end links are as good as any!
