Hotchkis sway bars
Discussion in 'Stop, Drop & Roll' started by Tokez420, Sep 6, 2004.
    jiggaman725 the black guy
    Ellicott City, MD
    for all those who have these installed...right now i have tein s-techs (lowered 1.9 in the front and 1.3 in the rear) and i was wondering if the sway bars would scrape over speedbumps and such from the car being so low?
    yes, they will...if you drive like an idiot :p
    i've scraped mine with Intrax springs, but i don't drive gently. just don't drive down near Damascus or anywhere near DC, and you should be OK.
    Dexterous New Member
    Stone Mountain, GA - USA
    I got a used set and from what I can tell, the grease fittings or nipples would probably rub on the front bar and wear down/break off; also the very bottom of the front bar has scrapes.
    It would be great to tap new holes for grease fittings at 9 or 3 o’clock in front mounting brackets like someone said; this will also require modifying the bushings with new inlet holes.
    What setting is the firmest on the rear bar, is it the most outer holes on the bar ends or the inner ones?
    Silver Bullet New Member
    The most outer holes are the softest setting. The inner most are the firmest.
    SBUBandit New Member
    I still have stock sways on my '00 Prizm, but my endlinks are really loose and I think thats some of the noise I hear now. Anyone know where I can get all four endlinks reasonable. The only prices I've found are $50 apiece. Does anyone make these aftermarket or know a better price?
    baymoe New Member
    So I finally got my Hotchkis swaybars installed. What a difference! The car is very responsive to steering input and bodyroll is reduced even further. Initially with my apex springs and kyb struts during highspeed turning, any corrections in steering resulted in understeer and tons of bodyroll. With the new bars installed, turns can be taken at greater speeds and steering corrections while cornering was very direct and with a more neutral handling. One of the best upgrade (lowering springs, strut bar, intake) I ever done.
    So what setting did you use on the rear bar, was it the most outer holes on the bar ends or the inner ones, or middle?
    middle is...well, the middle setting. outermost holes are the softest, and innermost are the stiffest.
