Hood tilt mod
Discussion in 'Exterior' started by GSE21tuner, Jun 2, 2008.
    this tilted hood thing makes the car look like it was in an accident. aesthetically i dont like it
    DeebsTundra Big Tires :)
    Near VoRtEx
    I think it draws away from the lines of the car. Real, flush functional hood or nothing. My two cents.
    cooler? does it overheat? i've never had an overheating problem with a toyota
    Near VoRtEx
    What's normal operating temperature range? My normal range is 3/4 of the way up the gauge too. :D
    turbo4age Love to Hate me
    NV
    think about wrapping that header.
    thrat would be the most logical solution.
    brownsville, tx
    itll cause turbulance and lift underneath your hood and make it want to rip off. if you do it do it right. tighten everthing. now excuse me, dora the explorer is on.
    plu Well-Known Member
    SC
    Hey you tried to replace the thermostats? Sounds like that is at fault. Replace that and you will pick up a few MPG too.
    i have the aftermarket header too and i drive pretty damn hard too and i have never gone up the 3/4 mark.
    as a matter of fact, my coolant hose is actually a lil pinched because i have the celica intake manifold installed as well.
    brownsville, tx
    dude i found the article on this. was taking a dump and took a random mag in there and it was in there.
    ok so its from "dear dave tech" in SCC. the guy asks about vents. he wants to put in a vent to cool his f22 turbo. so here was the response...
    rollatuner i presume you dont have on on your header. might under hood heat be the culprit to your high heat?
    so rollatuner, if you do open up the rear, you will let cool air in. but you will be sacraficing the airflow to your radiator. so i guess youll have a cancelling effect and be stuck with the same temp reading and a ricey hood mod. well i gues it wouldnt hurt to try it. see if you actually reduce your temp.
    and i just saw this and i totally agree.;)
    its_ikon FIRST widebody
    Henderson, NV
    maybe the idea came from the vw bugs? i personally think it is just a ricer kind of deal. there is no way to prove it does anything of substance.
    brownsville, tx
    i second
    the water temp gauges reads exactly that; water temperature.. its not a accurate form of measuring engine bay ambient temperature. If you want to lower water temperature, 1) get a thermostat that opens at a lower temperature, 2) get a high pressure radiator cap, 3) increase airflow into the radiator by using "cooling plates" around it to channel air into it.
    Also I agree with turbo4AG, wrapping the header is more logical.
    And I always agree with Dave Coleman, that guy is a genius when it comes to race car engineering.
    its gonna be a pita to wrap that header in its location. lol. and you've already got it welded right?
    careful when wrapping the header. i've known people who wrapped too much and ended up overheating the thing and cracked the header.
    Near VoRtEx
    It's run 3/4's of the way up the gauge since picking it up with 7 miles on it. Never had any issues with it.
    whatt? ive heard of ppl puttin that ceramic coatin and wrapping it as well..
    nyrican52884 Active Member
    Plymouth, MA
    So whats the verdict on the hood tilt?
    Ares Active Member
    Houston TX
    Best post in this thread.. LOL.
    Functional scoop or z3/m3 fenders = win
    Rincon , Puerto Rico
    looks good .......... You got pics of the underneath part ????
    How high is your tilt ???
    You cant get photos of it now ??/ Or is it a seceret ....LOL..... I understand if it is ....:)
    rayray1 Active Member
    I remember there used to be a guy that posted here who said that every time someone asked him about his mods. :D
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    i did this to my hood on my civic because i did a dualcam swap but im still using the singlecam radiator right now, once i get my fluidyne rad thier coming off :-D
