HEEEELP! Flasher doesn't work
Discussion in 'Interior' started by Vibe, May 22, 2008.
    After switching to LED turn signals i get the hyperflashing problem.
    I bought a new flasher to replace the OEM one to fix the hyperflashing but it didnt work when i plugged it in. I then replaced the OEM one and the flasher STILL doesn't work!
    What happened? How can I fix this?
    DaCubanSkillz Active Member
    I believe I read somewhere once that LEDs draw less power so when it replaces the OEM, the car thinks the light is blown out. I wish I knew where I read that from..and I think they had to use some type of resistor to fix the issue.
    This may or may not be the issue with yours but I thought i'd just give my input on what I read that one time.
    it turns out a blew a fuse. does that mean that i have to disconnect the negative before i switch em out? im afraid to try to do it again because i dont wanna blow the fuse again.
    brownsville, tx
    you blew a fuse because of the hyperflashing. i had the side marker that go in your fender up front in some mesh after i took out the stock lights, and i had the same problem. so i bought another set and wired it in to the same one and put those in the fenders.
    you can use a resistor but i dont know which one. anyone know?
    ive been hyperflashing for a while. i only blew the fuse when i tried to switch the flasher with one that is supposed to fix the hyperflashing issue.
    i forgot to disconnect the battery when i switched them out so i am wondering if that is the reason why i blew the fuse or if its because my flasher doesn't work.
    you blew a fuse.. most of those LED flashers are made by cheap chinese companies and arn't manufacured correctly.
    ugh so i guess i'm stuck with the hyperflash?
    dude I brought 2, both dont work
    I modified a stant but it blinks uber slow.
    Theres also the Nokya adjustable flasher but thats way too expensive.
    how much is that? i see their website but no price and cant buy it from their nokyiausa.com site
    i assume it does since it dosent sense load.
