Has anyone "dared" to run with 16x7 +35 on 98-02 Corolla?
Discussion in 'Stop, Drop & Roll' started by yakuza13, Oct 19, 2006.
    yakuza13 New Member
    A barely used set of wheels are being offered to me at a good price. They are 16x7 +35 with 205/45/16. I have a '99 Corolla CE lowered on Tein S-Techs, Tokico HP, Tein adj. front camber plates, Hotchkis sways (f&r). I know I will have fender issues but how much fender work are we talking about? Is it just a matter of rolling the fender or are we talking about major fender modifications? Thanks in advance for your help.
    I've run that backspacing and wheel size on TRD springs with KYBs - had to roll the fender lip in to get it from touching the wheel. If you have OEM style mudflaps - you will have to cut off the portion that runs along the fender lip - will be real obivous of which to cut off if you drive a bit and it touches. I found that it is not much of a wheel issue as tire choice - since a 205/45-16 tire from many manufactures vary slightly in dimensions for tread width. Example - I first ran with some Yokohama AVS ES100 tires - rubbed the fender like a mofo - swapped with a Kumho ECSTA Supra 712 tires, which are slightly narrower, doesn't even come close to rubbing. But I rolled the fender lip anyways to make sure that I could run a different tire in the future.
    jtweezy New Member
    Irving, TX
    show me some pics!!!
    Off topic.
    Since you are lowered with Tein S-Techs and have Hotchkis sway bars. Will you scratch the sway bars when you go over a bump?
    igorien2k New Member
    why do u guys even bother installing the front bar? it only hurts handling. just install the rear and set to stiffest :)
    Des Plaines, IL
    Ive got TRD rims which are 16x7 running 205/45/16. No issues here. Im unsure on the offset.
    jtweezy New Member
    Irving, TX
    hey mayur measure the offset of your rims please
    Des Plaines, IL
    Eh I would but they are already put away in an area that would take hours to get to. They are in my shed all the way in teh corner under a bunch of shelves. Then there is tons and tons of crap between that and the door and Im lazy lol. If you want to wait until the spring when I get em out Ill measure the offset.
    yakuza13 New Member
    I believe the 16" TRD rims have a +45 offset. I just need to make sure the +35 will work even with minor fender rolling/trimming.
    jtweezy New Member
    Irving, TX
    you machine the rims to fit better
    I run +38. Just roll the rear fender and dail in some negative camber.
    yakuza13 New Member
    :stupid:
    01rollas New Member
    mine are 215/35ZR18 w/ Velox Progear PG-C7 18' wheels, they have a +44 offset and i had to roll the small inner lip of the fender and the rear mudflaps as described above, but it no biggie, simply took me 20 minutes for both sides.
    Another thing i can't do jack shit to my camber since the wheels are bigger than normal, but it don't really hurt the tires as much from what i have experienced, i rotate them pretty often to hame as much even of a wear as possible.
    Corolla DX-R AE100
    Vancouver, B.C.
    i run 15x7 and its +32 offset hehehe but my ride is not lowered... i get rubs here and there if i hav ppl sit in the back...
    01rollas New Member
    i used to get rubs till i rolled the lip in and now it don't rub anymore, just my tires sit up and inboard alot, but the handling has increased substantially though.
    i run 205/40/16s +35
    Des Plaines, IL
    I thought you had 17s? You move down?
    oops typo
    17s i mean. lol
    I wanna move to 16s and get 45s
    or 15s with 50s.. when these tires wear out.
    Corolla DX-R AE100
    Vancouver, B.C.
    u are lucky ahhah after i rolled my rear fender... it still rubs alittle here and there...
    01rollas New Member
    yeah but do you know what i did, i expanded the side lips out about a 1/2 an inch.
    plu Well-Known Member
    SC
    I used to have 15X7 +38 offset and they rubbed until I rolled the fender. Then I got TRD rims and they fit perfectly tucked and also making the car lowered since it is tucked more. I find that offset is more of an issue with wheel gap than the fender rubbing. With the fenders rubbing, you can roll them. But if the offset is poking out like with my +38, the wheel doesn't tuck in and that generates a bigger ugly wheel gap.
    15X7 wheel with +38 offset
    16X7 TRD wheels
    j0x_rolla New Member
    tyler, tx
    yah roll the fenders
    i run 16x7's they look nice on the car fills it out
