Engine GTS swap anyone done it?
Discussion in 'Powertrain' started by Liquidgsr, Oct 31, 2008.
    Liquidgsr Well-Known Member
    Well from what I know, my Integra GSR high compression and I got a 2mm headgasket put on and boosted it at 15psi with no problems. The car also had 178k on it and i pushed the hell out it with no problems. Im sure a 2-3mm headgasket would do the trick. Thats pretty much all I did on my Integra, other than getting it tuned with cam gears since it changed the timing. Since we have a timing chain i do not know if its got any adjustablility. My Integra had a belt so it had some slack and could be stretched.
    I might just be enough. The only way to know for sure is to install the thicker gasket and do a compression test.
