Exhaust ideas needed
Discussion in 'General Discussion' started by coltron, 2009年09月26日.
    people here seems to like magnaflow:p
    DeebsTundra Big Tires :)
    Near VoRtEx
    Have you read the thread? :superconf
    this forum should be sponsored by magnafllow...
    i have an aftermarket-ish stock muffler.
    93geoprizm Active Member
    i got a magnaflow cat =)
    Phan Well-Known Member
    Orange County, CA
    i recommend this.
    coltron Coltron Design
    Sounds good to me lol/
    If i were to buy a mangnalow cat and put it on instead of my stock one, would i notice a different or no
    Orange County, CA
    no you would not. if you did a full exhaust system then you would.
    Oh okay so its generally recommended to buy a high flow cat with an exhaust (cat back) system?
    DOT. Noypi ako!
    Really? That's the first. Mine only screams at higher RPMs and at WOT, same feedback from other users I know.
    Hopefully your friend didn't get a knock-off.:confused:
    Swapping the OEM catalytic converter for a high flow will not net you any advantage - dyno pulls with the OEM and high flow cats in place versus a test pipe (de-cat) have shown no change in power and possibly 1HP gain max. Not worth the expense, unless you have to replace the catalytic converter that has already died. Sound wise, might be a shift in the frequency of the exhaust note - but your resonator and muffler will have the greatest impact on the final sound generated.
    Fish is correct. A resonator will also tend to smooth out the exhaust tone and eliminate any ricy pop.
