Engs Road: Route JCE10W
Discussion in 'Lexus' started by engs_road, Jan 6, 2021.
    engs_road New Member
    Ann Arbor, MI
    Drives off of T9
    When I purchased the car 2 years ago, the goal in mind was to build a fun family car that could bring the family (along with an extra set of wheels in the back) to the racetrack. Reliability, and maximizing seat time was also top priority!
    [IMG]Stock by ENGS ROAD, on Flickr
    Fast forward to now...
    [IMG]IS300 by ENGS ROAD, on Flickr
    ...and I've only been to 2 events. :lol:
    The first was a drift event where I ran into some drivetrain issues. The driveline had a horrible vibration. More on that on a later date.
    The second event was a track day where I was able to finally push the car for a proper shake down. The ceramic pads I was using started to fade half way through each session, so braking confidence was not there. The suspension setting was not ideal either. The car had too much rake, and I had toe out on the rear wheels. So, on braking and turn in, the rear end wanted to step out. It didn't make the day any less fun though. :naughty:
    I started to learn how the car was behaving, so I tried my best to do a fast lap. Still not fast lol. This is also on 300TW tires. Don't mind the RPMs in the video, the phone at the time could not handle all the data it was receiving.
    Since the last event, I've lowered the car more, took out the rake, and realigned it (2nd photo above).
    Sadly, most of my build photos were lost on my old phone, but I'll see what I can come up with!
    Goldy and 1nicetrd like this.
    Ahhh miss you in the west, But glad the socal track spirit is there.
    Loving the dad wagoo, keep this thread going
    engs_road likes this.
    Ann Arbor, MI
    Drives off of T9
    I miss driving with all the homies! I'll make sure to send all the things like I'm driving off of T9 for 'ol time sakes lol.
    I found some pictures in an old SD card! Nothing too good, but at least the thread won't be lame. :p
    MAINTENANCE
    When I purchased the car it was due for a timing belt, and it was puking oil from every seal.
    Good thing the previous owner included an Aisin timing belt kit (w/ water pump), and a Denso first time fit radiator! I rebuilt the serpentine belt tensioner with a new Nachi bearing. If you can't afford OEM parts, the next best thing is to get it from the manufacturer's supplier!
    [IMG]Dirty 2J by ENGS ROAD, on Flickr
    [IMG]Dirty 2J Pt 2 by ENGS ROAD, on Flickr
    [IMG]Rear Main Leak by ENGS ROAD, on Flickr
    [IMG]New Cam Seals by ENGS ROAD, on Flickr
    [IMG]Valve Cover by ENGS ROAD, on Flickr
    [IMG]NGK by ENGS ROAD, on Flickr
    [IMG]Nachi by ENGS ROAD, on Flickr
    I went with NGK spark plug wires and HPS silicone radiator hoses because racecar.
    Maintenance items were purchased from the dealership and those included, but not limited to; valve cover gaskets, cam seals, front crank seal, rear main seal, VVT-i gear, harmonic balancer, spark plugs, air filter, motor mounts, serpentine belt, thermostat, and exhaust gaskets. All the plastics, rubber hoses, and connectors were old, so they broke upon eye contact. The dealership was very happy to see me multiple times that week.
    [IMG]New Everything by ENGS ROAD, on Flickr
    [IMG]All done by ENGS ROAD, on Flickr
    There's a happy 2J :)
    Nobody wants to drive to the track only to work on their car. Maintenance before anything! You might notice some blue paint marks on the cam caps and harmonic balancer bolt. I try to make it a habit to mark critical bolts after torquing them down. It's to confirm that the bolt has been torqued to spec, and it's a quick visual to check if any bolts have loosened through hard driving. I guess I took these pictures before marking everything? I don't know. My underbody is pretty colorful though. :lol: Suspension post coming soon.
    1nicetrd and Goldy like this.
    Ann Arbor, MI
    Drives off of T9
    5MT Swap Part 1
    To make a short story long. The swap started before I even bought the car. I've been collecting all the parts. When I pulled the A650E automatic transmission off to replace the rear main seal, it was never intended to make it back in the car.
    [IMG]Pedals by ENGS ROAD, on Flickr
    If you're not familiar with this chassis, the 2JZ-GE variant of the Altezza Gita and the IS300 Sportcross never came with a manual transmission. Overseas, the Gita (Japan) and the IS200 (Europe) were offered with a 6MT that was paired to the 1G-FE:
    GXE10L-AWFVKw08/2002-06/2005GXE10 EUR WG LHD 1GFE MTM (credit to www.toyodiy.com)
    Lucky for us, that means the chassis was stamped for the clutch master cylinder for ALL LHD markets, not just RHD! Thank you Europe for having LHD vehicles, and Toyota for not changing your stamping die lol.
    To drill out the firewall, I like to make a cardboard template by tracing out the clutch master cylinder's mounting flange. Make sure you mark where top dead center is, so when you transfer over the markings to the fire wall, your clutch master is true and not sideways. Tech tip, use a knock out punch for the center hole for a buttery smooth cut.
    [IMG]Firewall by ENGS ROAD, on Flickr
    [IMG]Clutch Master by ENGS ROAD, on Flickr
    MT pedal set were purchased from Driftmotion. These are all OEM parts, and it came in like 30 different pieces. The scariest part was installing the huge tension spring, which I later deleted for better pedal feel.
    Actually, I started installing the pedals before I removed the A650E. AT Trans w/ MT Pedal set lol.
    [IMG]20181215_171207 by ENGS ROAD, on Flickr
    [IMG]pedals (2) by ENGS ROAD, on Flickr
    The first transmission I installed was the Aisin AR5 out of a 2006 Pontiac Solstice. It's based off an R154, so it shares some things in common. It's a great shifting transmission. I wish it had a traditional splined output shaft instead of a 6 bolt CV flange. You need a JZX110 shifter for it to work in the IS300.
    [IMG]jzx110 by ENGS ROAD, on Flickr
    AR5 next to the oil soaked A650E
    [IMG]A650E by ENGS ROAD, on Flickr
    Huge shout out to Curran on my.is he has a thread for an AT to MT swap, it's a great resource!
    Ann Arbor, MI
    Drives off of T9
    5MT Swap Part 2
    1JZ Flywheel with an Action Stage 2 clutch was installed for best street driveability.
    [IMG]1JZ Flywheel by ENGS ROAD, on Flickr
    [IMG]Action Clutch by ENGS ROAD, on Flickr
    I bought an MT tunnel and cut just the area I needed to mount the tunnel boot!
    [IMG]MT Tunnel by ENGS ROAD, on Flickr
    Yes, I used FIPG to stick on top of the AT Tunnel lol.
    [IMG]Tunnel Boot by ENGS ROAD, on Flickr
    No MIL! This is using an MT ECU.
    [IMG]Cluster by ENGS ROAD, on Flickr
    After the swap I signed up for a drift event to do a quick shake down. On the way, I noticed a slight vibration on the highway, and figured it was probably my wheels being unbalanced. I'm a noob to drifting, so I did a couple of laps, and spun out a bunch of times. The vibration became more and more noticeable. I called it quits, and was able to make it back home.
    I checked driveline angles, OK. I had the driveshaft rebalanced, OK. The vibration was stilll there. Upon further inspection, I believe the issue had to do with the 4 bolt to 6 bolt adapter that is needed to install a custom drive shaft to the AR5's 6 bolt flange. Was this the issue? I don't know. At this point I was tired of diagnosing. Tired of the constant jacking up, checking, driving, and feeling this never ending vibration for weeks. So, I bought a new JZX100 R154 from Driftmotion lol.
    [IMG]20200324_165902 by ENGS ROAD, on Flickr
    I opted for their IS300 Shifter Relocation.
    [IMG]R154 by ENGS ROAD, on Flickr
    [IMG]R154 (2) by ENGS ROAD, on Flickr
    Since the R154 was offered in most High Powered Toyota RWD Sedans, there are OEM solutions to fitting one into an IS300. As in, the IS300's AT crossmember rotated 180 degrees, and an OEM JZX100 Transmission mount (This will only fit JZX100 R154s obviously). This keeps your transmission and pinion angles in check.
    [IMG]20200309_202105 by ENGS ROAD, on Flickr
    The only modification was using Driftmotions shifter relocation, and "massaging" the passenger side tunnel as the transmission's center section of the case makes contact. You'll also notice the Superpro bushing that's inserted into the R154 transmission mount, and that the output shaft dust shield is missing. Don't worry, this was installed. We want a happy seal, not a leaking seal.
    [IMG]R154 OE Parts by ENGS ROAD, on Flickr
    Called the local driveline shop for a custom length MA70 Supra Turbo driveshaft (the differential flange is identical to the IS300 among other things, more on that later). Later that day my driveshaft was ready to be picked up! Anxiety filled the cabin that night. Slowly cruised up to 80mph. Smooth. Thank goodness. :D
    Ann Arbor, MI
    Drives off of T9
    Alright, we're almost caught up, please bare with me! Let's talk about
    Differentials!
    AT IS300s use a 3.9 Final Drive, while the MT uses a 3.7 FD.
    MT diffs are expensive, and I didn't want the stock 3.9 FD, so I picked up a 2012 FR-S diff which has a 4.1 FD. I really wanted a 4.3 FD from a 2017+ 86, but at the time, I guess noone has crashed any yet lol. One thing I love about Toyota is that their parts are compatible between platforms. The MA70 Supra, IS300, FR-S/BRZ share the same size ring and pinion, which means you can swap over final drives, torsen, or clutch LSDs if you wish. The differential case between the IS300 and FR-S are similar enough that they bolt right up without having to swap guts.
    Picked up the diff or "axle carrier" from a local wrecker. Not so pretty, but the insides were clean! Before pulling the torsen/ring gear assembly out, I checked the backlash and teeth contact. Mark which side your shims and bearing caps are on! I don't remember off the top of my head what the backlash was, but it was in the middle of Toyota's service specification.
    [IMG]FRS by ENGS ROAD, on Flickr
    Went to town with an air hammer to knock out the old bushings.
    [IMG]Bushings knocked out by ENGS ROAD, on Flickr
    The waifu and kid were out of town visiting family, so I took this time to paint the diff in the bathroom. Why not outside? because it was the middle of winter. Let's just say my bathroom vent was not efficient enough in evacuating the fumes lol.
    [IMG]POR15 by ENGS ROAD, on Flickr
    I don't have pictures of the process, but I removed the factory torsen, and installed an OS Giken 1.5 Way clutch type LSD. :love: Installing this was pretty straight forward. I bought new side seals and side bearings to install onto the OS Giken LSD, but I reused the shims that were on the factory torsen. Again, I hope you marked which side is which, or you'll be spending a lot of time on reinstall trying to figure out which side each shim goes. Once the LSD was bolted up with the factory shims, the backlash was still within service specifications. :thumbsup: If you don't feel like reusing shims, Toyota has a formula on picking out new shims. I didn't want to have to wait for a special order part, especially if I did my math wrong and had to order it multiple times.
    [IMG]OS Giken by ENGS ROAD, on Flickr
    Installed with SuperPro Bushings...
    [IMG]Super Pro Diff by ENGS ROAD, on Flickr
    ...they were too squishy still, probably because both wheels now had traction? I switched over to Serialnine's delrin bushings. I was afraid it was going to be louder than the SuperPro's, but surprisingly I didn't notice an increase in NVH.
    [IMG]S9 Diff by ENGS ROAD, on Flickr
    OS Giken is one of the top tier LSDs, and you wouldn't even know I had a clutch type in my car. There is no harsh engagement or noises from daily driving, or from low speed maneuvers. Coming from a torsen LSD, I can say that clutch types are consistent in locking up. My old GS400 had a torsen, and it was a 50/50 chance if it locked up. On one lap I would be powering through an oversteer, and the next lap on the same corner, I'm uninstalling my front lip off the beaten path. :lol: Clutch type LSDs are where it's at. Should be top 3 on the performance mod to do list. :D
    Ann Arbor, MI
    Drives off of T9
    Suspension Tune
    The car pretty much has Figs Engineering's catalog.
    I rebuilt the front end with Superpro's non-adjustable bushings, and a new ball joint.
    [IMG]Superpro Rebuild by ENGS ROAD, on Flickr
    Coilovers by Powered by Max / Partshop Max
    F: 14K
    R:12K
    [IMG]Powered by Max by ENGS ROAD, on Flickr
    Sway bars by Hotchkis
    Front and Back
    [IMG]Hotchkis by ENGS ROAD, on Flickr
    Lower Control Arm, Traction Arm, and Toe Link by Figs Engineering.
    [IMG]Figs by ENGS ROAD, on Flickr
    Not pictured are all the spherical bearings that were installed on the rear spindles. The rear UCA is still factory w/ old untouched bushings, but that's going to be changing soon! :)
    [IMG]IS by ENGS ROAD, on Flickr
    That's pretty much it for suspension, I couldn't find any more pictures.
    ENGINE TUNE:
    It's stock.
    All I have is an HPS cold air intake and a Greddy Revolution RS.
    aaaaaand we're all caught up!
    vortex, 1nicetrd and Goldy like this.
    So much fun hidden under that thing... Talk about a shit ton of work. Nice job!
    I also always enjoy seeing some of that awesome color in mods for suspension and other goodies. Call me lame but I feel like that just adds to the personalization aspect of functional modifications.
    Oh yeah, you definitely added all sorts of HP with all those colorful suspension bits! :lol:
    That's awesome though, I got to that point with my car (needing all those suspension overhaul updates) and decided it was just too much and passed on the car.
    Ann Arbor, MI
    Drives off of T9
    Thank you! and we're not even close to being done yet lol. The colors are cool. Too bad no one will see them, unless I flip the car at the track. :ashamed:
    Just you wait Goldy, sticker power mods are coming. :p whoa whoa whoa, hold up. Passed on the car? Do you not have the IS300 anymore? or am I misunderstanding?
    But for reals though, I bought High HP RUCAs for my stock power car. :rofl:
    [IMG]Kids college fund represented in steel by ENGS ROAD, on Flickr
    I'm excited to install Figs' road race hysteer knucks :love:
    [IMG]RoadRace Knuckles by ENGS ROAD, on Flickr
    I ordered the RUCA without any spherical bearings/bushings because I had some Superpro bushings that I never got around to installing on the stock arm. Here they are now in their new home. :)
    [IMG]RUCA with SuperPros by ENGS ROAD, on Flickr
    These will eventually get installed after I finish a few other things. :joyful:
    vortex and Goldy like this.
    yeah I put it mostly back to stock to sell the good parts separately, and sold the car away for almost nothing in the fall. Keep up the good work and enthusiasm for us all!
    Ann Arbor, MI
    Drives off of T9
    So...what's the new project? ;)
    Sitting at home in lockdown for the rest of my life haha
    All these goodies !!
    LOL flipping the car is not an option, but at least you can do it in style. :D
