Engine BAy cleaning?
Discussion in 'Exterior' started by MstwntdFlip, Mar 17, 2009.
    MstwntdFlip Well-Known Member
    Any body know how to clean the engine bays of there cars.
    i went to a coin op and they had the engine cleaner selection but i was to afraid to use it being afraid of damaging anything, is it ok to use the coin op washers or is there another way?
    you just need to avoid electrical components like the alternator, maf sensor, and coil packs.. if you get any of these wet then dry them immediately. And don't get too much water on the header when hot.
    I use the Black Magic Engine Shine degreaser. I have used it for 5 years now with no problems. I just go to a DIY car wash and pop the hood. Spray off the engine, and then use the degreaser on the engine, spraying everywhere. I then let it sit for about 5 minutes and then sprays the degreaser off.
    I have never had any problems.
    Graphiterolla Member
    Macon/Warner Robins, GA
    i have sprayed mine down with simple green, let it sit, and then sprayed it off with a pressure washer. ive never had any problems either
    Salty_Dog Old Fart
    Fredericksburg, Virginia
    Don't use a pressure washer. Just use a good engine cleaner/degreaser on a warm (not hot) engine, and rinse it with a garden hose.
    I have never had any problems with a pressure washer.
    neither have I.
    Just have to make sure that your not taking the nozzle and putting it right up to the intake..Which I am sure that everyone on this board is smart enough to realize :)
    some detailers have steam cleaning services. Dats the best and safest. Youtube it!!. Its like magic.
    heres a good video. Pretty neat
    like magic the gathering magic or harry potter magic?
    you don't use a pressure washer because it forces water in to spots it wouldn't normally go. can cause wiring or other problems
    maybe some of us have just been lucky then. ive been using a pressure washer for years. It is only a 2600 psi and not an industrial 3800psi but it has never caused me any problems. as long as everything is sealed up i dont see a problem. if you have exposed wires or bad seals, i could see where some issues would come up.
    well even the industrial car washes lower the water pressure in engine bay cleaning mode. It's not much different than traditional garden hose pressure.
    so really i dont have to cover up anything juust dont spray to hard and im good
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    Well yeah everything can get wet underneath considering we drive our cars in the rain. Just dont hold the sprayer on the Alternator Coil packs and fuse blocks. Anything electrical related and you should be fine. I was told to do it with the car running but im not sure if thats the proper way.
    cool ill just try to spray the engine part xD
    my dad would cover up the coils entering the cyclinders with a bag. He got water into the cyclinder once and he had to change the spark plugs. Heads up = ). If u push the coils down hard enough though, that should ensure a good seal though.
    Don't be lazy, just find a plastic bag and cover up the alternator and maybe put a towel over the coil pack. Be a man, do the right thing!
    That is what I was told as well. And that is how I continue to do it :)
    just get a toothbrush and a precision spray bottle. go all out and be anal
    Hahahaha. That would be funny
    But a good Idea to get into the tight spots
    Ares Active Member
    Houston TX
    Easy for you guys, I have 9283461 feet of tubes and lines in my engine bay.
    And yes, I desperately need it cleaned too...
    would i need to covber the batteryand unplug the negative circut? or i wont have to
    and why do some people say keep you engine running
    Des Plaines, IL
    Meguiar's Super Degreaser + Meguiars Hyper Dressing.
