    Now it actually looks like a real BoMeX piece! Nice work dude, that thing will look hella clean.
    almost, im the only one that has slimmer side skirts, de-riced front bumper, and decent rear bumper
    Once the bumper was on i just realized the bumper needs more sanding...
    This better look good.
    Nice cbass, that is looking really good man. You actually go to those Fremont meets even tho it's hella far from Stockton? I wanna see your ride in person!
    reminds me of this front bumper, except for the fogs and sidemarkers ;)
    its not that bad, only a 50min drive...i usually put like $13 of gas and i can go and come back, im mostly down at the bay thursdays but you can also spot me on one of the meets.
    ohhh boy:rolleyes:, but yea kinda does look like it...maybe i should just install the actual altezza altezzas...it would be called corotezza
    corotezza lol
    I thought that would have been ebough to bring gold back but I guess not.
    i should go look for him since i live closest
    hes creepin?:eek:
    soooo i want to know is there some sort of filler that i can use to fill in these gaps and can be sanded downs???
    basically right now screws are holding the skirts but i want to cover the cracks with some sort of filler like something for windows but that can be sanded down and maybe also sticky
    Your asking us, macgyver?
    Yeah come on you're brown.
    /cRacist comment
    Yeah, all brown people know that kinda stuff. Maybe hes just been in the sun too much?
    fuck...:(...and they called me racist
    but all i know is fiberglass and bondo...
    Just bondo everything.
    friend gave me some stuff that seems to work, will let it dry
    anyways same friend came over with his scanner and i got this code out....
    p0420 catalyst below threshold
    says most likely a sensor, i told him i had replaced my 02 sensor before cat and i had it not working for a good month the last one. He now tells me to clean/change the one after the cat and if that dont work and he says "call me crazy but dump that cat in a big contain with soapy water to clean it, let it soak for a good hour or two"...this is coming from a guy that drives a 240sx.
    sigh sounds better than my code. I have to get the smoke evap test
    Me too. Have a leak somewhere, or maybe one of the 500 valves in the EVAP system is bad.
    but i dont have a leak, i think....wait isnt p0171 the leak one? i fixed that a while back, all my gaskets after the exhaust manifold turned into dust from all the heat...
    i have p0420, checked online and most common reason for this gen is the sensor after cat, or most of the time its CEL that cried wolf..... idk if you saw my pre-cat 02 sensor, that shit was corroded as fuck. the air flows to the after-cat sensor so maybe the sensor is corroded or worse i have a poised/dirty cat....the after-cat sensor i have never replaced it...i want to pass fucken smog already!
    I have 441 which is a purge flow error, it's all my fault though. Tax money = crooked smog yo
    lol how? and is that worse than mine? shit i might have to replace a cat or borrow one just to pass and worry about it in another 2 years, still get great gas mileage so I DONT GIVE A FUCK BOUT A CHECK ENGINE LIGHT!
    Added: Feb 26, 2012 7:05 AM
    wait, by reading topping off can cause a CEL? fuck!! sensitive ass car...
    ohh i found a haynes manual for the corolla at my local thrift store for 5 bucks, has 7th and 8th gen...pretty cool
    Yeah don't top off. Just get a crooked smog yo and ignore the CEL.
    you know of a place?
    Gonna find one today. Just go to a meet with all the cool dudes in their Civics and ask around. There's no way that all those cars are compliant with CARB.
    This page sure went many directions... lol.
    Cbass, glad to see you did something on your car, even if it was right after I "went away". Any more progress?
    "corotezza" lol. Sorry, it didn't bring me back ....
    But you can have my altezza altezza tail lights for free lol.... I need to replace them.
    a crap load...just gonna show teaser pics for now tho
    what the hell are you gonna get? and r u serious?:confused:
    They're probably broken, hence needing to be replaced. I think he got rear ended. (insert sexual Mack joke here)
    Yes, my beautiful tail lights are broken now :(
