    x2
    It's OK cBass, they're just Jelly of the glorious BoMeX.
    :please:
    There's almost nothing left of the original Bomex! :fyeah:
    And BoMeX never made their kit for this chassis, so it was never an original to begin with!
    well....the side skirts are kinda the same just made them more flushed with the body so HA!!!
    Non sequitur fail.
    No pics = fail.
    So much Own.
    :dafuq: on my carro!!!
    OK, so your side skirts are not modified. You win.
    Yeah this bomex "style" kit is so dumb, it looks the same on every car ha
    Proper :roast: good :sir:.
    Indeed good :sir:
    Why, thank you :sir:.
    You're very welcome :sir:
    lol my uncle gave me some old import tuner magazines from back in 03 and that same body kit is offered on like all the cars...you just have to specify for what car and they are like 600 o_O
    And now you have one, your child-hood dream come true!!
    ehhh.....no
    Old???? :mad:
    That would be me.
    JK! :troll:
    Milky Enlarged Member
    from reading the updates, the 7th gen knuckles put the tie rods at the wrong angle for a stock height corolla... but what about a lowered corolla? i know from lowering many cars, that bump steer is an issue and it almost sounds like those knuckles could eliminate bump steer or at least reduce it. but it also sounds like you need a shorter axle? like it was putting it into a bind?
    it also sounds like if dr tweak said use the corolla/matrix/celica knuckles, then it must work, just needs to be realigned. not a big deal really.
    Yeah dumping these cars totally changes the geometry.
    i cant tell if that is sarcasm or not. lol. but i know i have a bit of bump steer.
    Nope no trolling here lol
    Obvious post is obvious lol.
    Added: Apr 5, 2013 at 7:13 AM
    Speaking of which, I'm gonna get my first-ever alignment today!
    Hahaha, nice.
    I think it gets much better when you're lower. My steering tie rods are almost parallel now (which means my LCA is past parallel). Bump steer is as minimized as I've ever felt it.
    yeah, its not too bad right now really. my miata was worse. hell it was horrible in the rain, it would bump steer and the back end would get all nervous from -1.5* camber and a bit of toe in. but nice dry ground on a warm day... curvy back road... dear god!
    So what's up with rear toe? What should I be running for MAXIMUM CORNERING PROWESS?
    Front toe?
    well, since the miata uses double wishbones front and rear, you have a wee bit of toe in, in the rear. this is mostly because its a rwd vehicle and will make it more stable in the straights and a bit easier to get the rear to rotate in a corner. as for entire alignment specs on the miata, it was as follows:
    front:
    toe: 0'd out.
    camber: -1 degree
    caster: 5 degrees
    rear:
    toe: -0.2 degrees
    camber: -1.5 degrees
    fwd vehicles are a bit different to setup for handling, esp ones like the corolla. i try not to run much toe, if any, on the corolla, cus it eats up tires much quicker than the miata. for the corolla, right now i am currently at :
    front:
    toe:0'd out
    camber:-1.5
    caster: not adjustable
    rear:
    toe: 0'd out
    camber: -1.5
    it handles fine, no abnormal tire wear. the miata would eat through a set of dunlop direzzas in about 8-10k, so far with the corolla, im at 10k on the nitto neo gens and still plenty of thread.
