DIY DIY: How To Change Your Window's Belt Molding
Discussion in 'Other DIY & Questions' started by plu, Jun 30, 2008.
    plu Well-Known Member
    SC
    So your window's belt molding is looking worn out like mine here, eh?
    Well, here is what you need to replace them:
    Part Number:
    75740-02040 Rear Left Door
    75730-02040 Rear Right Door
    75720-02050 Front Left Door
    75710-02050 Front Right Door
    67869-02020 Plastic Door Weatherstrip Fastener
    Tools:
    (2) Flat Head Screwdriver
    (1) 10 MM Socket Wrench
    Front doors:
    1) The front doors are the hardest. You have to take out your side mirrors. So use your 10MM socket to loosen the 3 bolts and take off mirror.
    2) Roll down your window so you don't scratch the glass and give yourself more room to work. Use your screwdriver to pry up the old belt molding.
    3) The front of the belt molding is held in place by a plastic fastener pictured here.
    4) You want to pull back the door's weatherstripping to expose the plastic fastener. Use a screwdriver on either side of the fastener's head to pull it out. I think it is a one time use fastener as I could not reuse either one of mine.
    5) Take off old belt molding. Align the new belt molding by carefully placing the edges to the slots on the door. Secure them in place by just pressing down on the molding. Don't forget to replace the fastener and put back your side mirror. That's it!
    Rear Doors:
    1) The rear doors are real easy. Roll down your window. Pry up the old belt molding with screwdriver.
    2) You should see these blue tabs remaining from your old belt molding. Just slide them down towards the end of the door and they will come off.
    3) Align your new belt molding on the door and press down. The molding should click in place. That's it!
    off topic: what kind of wheels are those.
    im going to do that. that stuff on my car looks all funkied up.
    Ares Active Member
    Houston TX
    Looks good. (Although I just zoomed through it)
    I also need to do this to my car. 20yrs old ftL
    sting 101 The 80's Icon™
    nice DIY... hope one of these days, i could do the same to my car...
    how much did those cost?
    twenty bucks tops. im guessing.
    OMG perfect timing! I just noticed by window molding on my front driver's side was bad a couple weeks ago. I'll follow it step by step. Thanks for sharing the info! :D
    I wish moldings & weather stripping didn't cost so much, I wanted to change the top weather stripping for the longest time.
    SC
    Those are 16" Enkei DM5 with +42 offet. Good luck finding a set as they are been discontinued. They might still have some in +38 offset but they will rub a dub.
    They cost $30 - $40 a piece from an online Toyota discount parts store, but MSRP is $50ish. :nutkick:
    :nutkick: :nutkick:
    :nutkick: :nutkick:
    can you tell me which site u used?
    pm it if u want
    SC
    Do a Google search on Toyota Discount Parts and you will get a bunch of sites. Type in the part numbers to compare each site. Whomever has the best price varies week to week. Don't forget about the shipping cost.
    jdmikey New Member
    i just painted mine flat black. doesn't look bad. just sand them down before paint.
    hmm i cant seem to find those part numbers..
    SC
    Type them in without the dash if it doesn't work
    Des Plaines, IL
    Hmm well I only have 41k on my car and mine look brand spanking new! lol.
    Phan Well-Known Member
    Orange County, CA
    odd... my car has only 38k mile, back then my mother would always garage the car but some how the belt molding still faking away then black particles.
    i have 100k more then you.
    My situation is even stranger. I park it outside a lot and only the driver's side front is flaking. The other three are still rubbery thick and supple. :superconf Maybe I'm just too hot when I sit there. LOL :D
    JordanInc ZZE110
    theres another method to do it, my friend did it to his car before...
    apply a long strip of decals [;
    I'd rather not attract more attention then I already am. LOL
    Des Plaines, IL
    My car always used to be outside when my mom drove it. Now it sits in the garage lol. But your from cali right, alot warmer there than here in the windy city.
    SC
    The rubber peeling off the molding isn't just a cosmetic issue, it grips your windows snug so debric or water doesn't fall inside the door.
    Orange County, CA
    true, here its always summer
    atomicaz Member
    Socal
    RISE THREAD RISE!
    Sorry to bring this one back from the dead, but I am about to do allllllll four of my window moldings and this DIY is a great help.
