DIY- Celica seat swap for Corolla
Discussion in 'Interior' started by Irvin, Sep 10, 2013.
    Shits strong....im amazed by it. If anything i used it to keep the brackets clean because they were chewed and scratched up from when i drilled the spot welds...
    NPF is strong
    but yeah the strength comes from the bolts and welds
    Coca_Rolla Member
    Toronto, Canada
    1998 Toyota Corolla CE
    :orly:
    Added: Mar 1, 2014 7:20 AM
    I tried finding that info but it was all dead.
    That's why I did it the way I did. It works!
    Milky Enlarged Member
    wasnt vamp posting in here not too long ago?
    He said he still has the complete website but no server to up it.
    Coca_Rolla Member
    Toronto, Canada
    Yeah i might go that route, looks like less hassle overall. And do you mind snapping a pic or two of the L bracket you used? Just trying to figure out what you did there..
    Blaming me for shaking your seats violently... LMFAO. A gentle wiggling should be no issue. I can guarantee you that the force exerted on those welds will be many many times greater than that if you get in an accident. If you were nervous that I shook your seats too much, that means you aren't confident in your work, and those seats shouldn't be sat in, as they are obviously dangerous.
    James and Gold like this.
    ^^^ Precisely. Spoken like a hella true boss
    Or if goku farted on it
    I thought you might feel that way :pfftch:
    No, I knew you'd feel that way, because I'm not new here.
    mack, they were never welded when i took them to toyofest, i only had the screws on at the time...and even that was not enough...and the welds i did not do, i had my uncle do them....i should of took them to him from the start instead of taking them to that family friend of mine...he did not line them up right after 2 trys....im sure you remember that story from last year....but anyways they are solid now, 3x
    Seems legit!
    We'll see if it passes my apparently extreme seat shaking test.
    LMFAO!!!! PERFECT :bowdown:
    Coca_Rolla Member
    Toronto, Canada
    Do the seat belt harnesses have to swap over with the celica seat? and are they compatible with the corolla seat belt & retractor? What needs to be done to remove the seat belt light from the dash after the swap?
    The seat belt warning light harness is different. All I did was ground the seat belt harness so that the car thinks the seat belt is always buckled up/connected.
    You can use your current seat belts.
    Coca_Rolla likes this.
    Coca_Rolla Member
    Toronto, Canada
    Ok, cool, i heard you could also splice your connector from the corolla seat to the celica seat so that the connections will be the same... i guess grounding it is basically the same way, if not easier.
    its different. thats all i know. maybe irvin can shed some light on what he did?
    I haven't actually fixed this issue yet. I need to look at the wiring diagram. The Celica connector has 3 wires and the Corolla has 2. Now, I suppose if you want to have the seat belt light off always. you can do what Cbass did. I'll look into this this weekend.
