DIY DIY 93 - 97 Corolla Right Front Motor Mount Replacement
Discussion in 'Other DIY & Questions' started by RinconRolla98, Apr 18, 2013.
    Rincon , Puerto Rico
    This DIY is for the Motor Mount in the right front .
    On some Corollas there is the cruise control that needs to come out because it sits on top of the mount and you need to remove the windshield washer fluid canister as well . Plus the top of the motor mount has a cap on it that needs to come off as well .
    Now make sure you raise the one side of the car and place another floor jack to support the oil pan and to keep the engine from tilting . The motor mount bracket goes into the the timing belt area . That part you do not remove . All you have to do is go under the car and remove the 2 bolts that hold the motor mount to the bracket .
    Then you can remove the upper bracket that holds the A/C line that goes over the mount , Then the other 3 bolts that hold the mount to the frame . No need to remove the center nut of the motor mount until it is off because you have no clearance .
    Once you remove the motor mount then you can remove the center bolt of the motor mount and put it to the new one .
    Then you can put everything back the same way you removed it .
    For More Info or Questions go to http://rinconrolla98.blogspot.com
    What brand of replacement mount do you recommend? Are those OEM?
    Thanks for the DIY Rincon!
    Not really.
    Yes Hummer, Mack knows what Mack knows. DAB
    Master Dicklet likes this.
    Did you even read the thread bro? no, lol.
    He had himself at :orly:
    Read the threads? :wonka:
    That's what I was afraid of.
    SB;hw
    Super lulz here.
    The whole page
