Engine Crazy Engine Swaps I'd Like To Do...
Discussion in 'Powertrain' started by Dr Tweak, Feb 25, 2007.
    DOT. Noypi ako!
    Would you guys know it the 6-speed transmission from a 2zz would fit the 1zz?:)
    Dr Tweak Mad Scientist
    Savannah, GA
    Yeap, sure will.
    -Doc
    DOT. Noypi ako!
    Wow. Just like a bolt-on mod?
    Nice, how much would you think this project would cost Doc? Thanks.
    Savannah, GA
    In your car? No, you're going to need custom axles and some work done to the mounts.
    -Doc
    sr20dett =] i dare you
    01rollas New Member
    350 Chevy Smallblock? that with a carburetor? hehe
    Wait on second hand just throw a new 5.7 L V8 off the tundra 381HP works great.
    Savannah, GA
    Legit01Rolla Active Member
    nice sig slow!
    Tulsa, Ok
    I personally would like to see a rwd conversion with a 2jz swapped into an 01-02 rolla....I would so switch back to that model corolla if I could help make that happen...
    rayray1 Active Member
    My ideal car would be a 200hp N/A AE86.
    01rollas New Member
    even that amount of power is not enough, trust me. i still need more , but i need a bigger turbo.
    d3athm3talh3ad New Member
    j-spec ae114 is all wheel drive, would probably be the easiest platform to start with for any awd corolla project...
    JLee TD05 3SGTE
    NH
    Doc! Long time no see...my old '98 might be up for sale sometime, if you know anyone interested in a turbo/rebuild -- already has the ACT clutch and Fidanza flywheel. Burns a bit of oil, but nothing a (8.8:1 ;)) rebuild wouldn't fix! Could be a good project for someone... ;)
    It's obviously your call, but I wouldn't hesitate to leave my car down there. Then again, I'm probably one of few here that have actually met the guy. :)
    Savannah, GA
    :) Thanks
    I'll keep the car in mind, I haven't talked to anyone yet who's looking for one though.
    -Doc
